Go to Post I give props to your programmers and programming mentors. - Sgraff_SRHS06 [more]
Unread 07-01-2009, 01:54
Aren_Hill's Avatar
Build Nifty Things
No more "bolt and fastener"!!
BUMPERS must attach to the ROBOT with a rigid fastening system to form a tight, robust connection to the main ROBOT structure/frame (e.g. not attached with Velcro!). The attachment system must be designed to withstand vigorous game play – nut and bolt fasteners are recommended. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
Woot! so lets see them nifty quick release bumper designs, i know i'm looking forward too not having to whip out a ratchet to pull off bumpers
A guy who likes robots.
Unread 07-01-2009, 02:10
run the trap!!!
Team Role: Human Player
Re: No more "bolt and fastener"!!
So.... um... why are bolt and fastener systems not allowed?
-Philip J. Fry
Unread 07-01-2009, 02:13
Aren_Hill's Avatar
Build Nifty Things
i was excited over the fact we were not forced to use them as in past years, opening up lots of nice possibilities
Unread 07-01-2009, 02:45
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Heh, with so many limitations elsewhere, a lot of the variation is going to be in the bumper mounts. Imagine a GM Industrial Design award for the quickest release bumpers.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 07-01-2009, 08:16
GaryVoshol's Avatar
Cogito ergo arbitro
They are allowed and even recommended. They are not required.
(since 2004)
Unread 07-01-2009, 08:20
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
we use wing nuts...
Is now an engineer thanks to FIRST.
Unread 07-01-2009, 09:07
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
We designed some awesome quick-release bumpers last season, forgetting that the reason we used the undesirable bolt-and-fastener method because it was required. (: I'm glad to see we can actually make use of this now!
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 07-01-2009, 09:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Well, sure we can design quick-release bumpers this year...but I'm pulling my hair out over the rule that says all regions of the bumper must be supported by the robot. E.g. no gaps for cantilevered wheels. Sure we'll all get over it but I think it unjustly complicates a simple design concept.
Can anyone think of a quick-release that can be mounted to foam? It's like a mix of lightweight foam and styrofoam. We could always use 2" bolts with wingnuts that go through the foam to the aluminum frame, but I wonder if there is a better solution...
GitHub
Unread 07-01-2009, 09:28
AKA: Ellen McIsaac
I'm not sure exactly what you're describing, but I have a feeling that foam is not the best solution in this game, where there are going to be many collisions and lots of bumper-to-bumper contact. It doesn't sound like it will last...
If you're worried about trying to make sure your bumpers work with your wheels configuration, perhaps you could segment your bumpers? Or, if you could give a clearer view of the issue you're describing (I know you said that you have a really awesome drivetrain planned, but if you can do this without unveiling the whole secret), maybe we can suggest other solutions?
Ellen McIsaac
Unread 07-01-2009, 09:47
JesseK's Avatar
FRC #1885 (ILITE)
The frame design is similar to a crab drive, and the wheels will be cantilevered. The KOP wheel dimensions and the strict bumper rules have really restricted the simplicity of this design, but we're not afraid to overcome it.
We will have an 'upper' frame and a 'lower' frame that will have hard connections to each other. Unfortunately, the upper frame will be above the top of the bumpers, and the lower frame will be at the very bottom of the bumper. Due to the cantilevered wheels, there will be a gap between the frame and the bumpers. The foam is meant to attach to the outer perimeter of both frames, and fill the gap to become the outer edge of our robot on the sides. This is so impacts will be spread between the upper and lower frames. There is no other simple solution to this, since moving the upper frame out further would overcomplicate the whole frame design.
The foam is used in an industrial application at Micron (one of our local sponsors) and their mentors said that as long as the force is spread out over a few square inches the foam will be ok since there will also be bumpers to absorb the impacts. So essentially the foam is like an inner bumper that is part of our robot and meant to also redirect some of the impact force to the upper frame.
Yet due to the design of the lower frame, and the unique feature of the drive train, the foam cannot extend into the corners like we were originally thinking...so we will have to derive a solution for that by the time the whole drive train is done. We'll sit on it until we find a simple solution that doesn't require intricate welding (which is what we've come up with so far).
GitHub
Unread 07-01-2009, 09:51
AKA: Ellen McIsaac
Yes, I can see how that is causing problems. Unfortunately, I'm not enough of an expert on drivetrains or bumpers to come up with an ideal solution to this problem. The foam sounds like it might work, but I'm guessing other people might stop by here and offer their insight.
Ellen McIsaac
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
