Go to Post "I'm not teaching you math, I'm teaching you how to think. Hopefully that'll be useful to you someday..." - Karthik [more]
Unread 07-01-2009, 07:44
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Autonomous questions (Labview) and some general issues
I can't get the autonomous to work, when I switch from TELEOP to AUTO at the DS, nothing happens. Could it be my very simple autonomous test code?
here's my code:
btw, should I remove all controls and indicators from the VI if I want to use the robot not connected to the PC?
Thanks!
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 07-01-2009, 08:16
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Autonomous questions (Labview) and some general issues
all i know is most programs in labview don't work until they are within a while loop,(so you can control them from the dash board) trying creating a while loop to execute when in autonomous mode. If you use a case statement, that is fine, but the control panel won't see that their is anything to run the program with, it needs a while loop to run in labview, idk about in the cRIO.
Is now an engineer thanks to FIRST.
Unread 07-01-2009, 08:17
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Are you clicking the run button on Basic Robot Main.vi or Autonomous Independent.vi? I don't believe that the Autonomous Ind VI will run on its own. I think that everything needs to be setup by using Basic Robot Main.vi as the highest-level VI (especially Ethernet comm).
Russ
Unread 07-01-2009, 08:28
Daniel_H's Avatar
I click RUN at the Basic Robot Main.vi
I changed very few from the original autonomous code
[<o>] gogogo [<o>]
Unread 07-01-2009, 08:30
XXShadowXX's Avatar
They call me Cody.
do you mind if i start working with dx/dt for the joysticks, that is an amazing idea
Unread 07-01-2009, 08:45
Daniel_H's Avatar
go ahead, and tell me your findings
I already got it working, but didn't implement it on traction control yet. I want to add some inertia to the controls to improva acceleration, since sudden fulls on the joysticks will make you slip
[<o>] gogogo [<o>]
Unread 07-01-2009, 08:47
XXShadowXX's Avatar
They call me Cody.
I haven't started on traction control, I'm still working on ballistics, and tracking. But 3d calculus is giving me a headache so I'll see what i can come up with.
Labview can do trig right?
Unread 07-01-2009, 09:00
You don't need to remove the controls and indicators before building and deploying as a startup application. I don't believe that these will impact the final performance at all when running as a startup app since the "compiler" will strip off the UI goodies when unnecessary.
I'd recommend that you set some breakpoints in Autonomous Independent.vi and see if the application actually jumps to that VI when you toggle the switch on the DS. Maybe the changes that you've made to Basic Robot Main.vi have somehow defeated Autonomous Independent.vi. For example (and I haven't dug deep enough into the architecture to know whether this is easily accomplished), an infinite loop in teleop may never let the main state machine jump to Auto Ind VI.
What's shown on the DS screen when you switch to Auto?
Russ
Unread 07-01-2009, 09:37
Daniel_H's Avatar
somehow it is toogling teleop to auto again, but it still needs to be connected to the PC and running, otherwise nothing happens.
[<o>] gogogo [<o>]
Unread 07-01-2009, 10:03
In order to run without your development PC attached, you need to build the app, deploy and set it to "run as startup".
http://decibel.ni.com/content/servlet/JiveServlet/previewBody/2631-102-2-4099/FRC_Programming_Guide.pdf;jsessionid=82a40f1a30d63 f03c468b58846e5bb8cdea6056bf7c4.e3mNbNaPb3iNe34Tbx aPbhuMchb0n6jAmljGr0
All teams should check out the above link. It's the complete (IMHO) LabVIEW for FRC guide and includes instructions for deploying and running.
If the above link breaks for some reason, the document can easily be accessed through FIRST's Control System portal at http://www.usfirst.org/community/frc....aspx?id=10934 (see LabVIEW Robotics Programming Guide).
Russ
Unread 07-01-2009, 10:06
Hitting the run button only loads the program into RAM. You will need to build->deploy->run as startup for it to persist.
Unread 07-01-2009, 16:12
Daniel_H's Avatar
Do you mean that I never really wrote a code that would be there after I reboot the cRIO? omg
I think I didn't understand how to do that. Where are those commands?
[<o>] gogogo [<o>]
Unread 07-01-2009, 16:39
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
There is an entire section in the manual which Russ referenced which goes over building, then deploying an application. Try it out.....it's easy. At least you didn't lose your code.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 08-01-2009, 18:11
Daniel_H's Avatar
I read chapter 5, but I'm not used to the terminology yet, so what does it mean to "Create a Stand-Alone FRC Application" from page 45 and "Deploying the FRC cRIO Robot Project" from page 41? Don't both of them work for the software to persist?
Anyway, I went to Build Especifications under RT CompactRIO Target (10.11.56.02), right-clicked it and hit "Build All" and i got the following error message:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->
AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards \FRC\FRC Templates\builds\FRC cRIO Project\RT CompactRIO Target (0.0.0.0)
\FRC Basic Robot Deployment\c\ni-rt\startup\NI_FPGA_Interface.lvlib_NIFPGA System
[<o>] gogogo [<o>]
Unread 08-01-2009, 20:56
I believe that the Error 6 message is the result of known bug in the 1.0 LabVIEW FRC version. You need to upgrade to 2.0 using http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180. Be careful, I think that you'll need to open a new FRC cRIO Project after installing the upgrade since your old project will have old links (you might be able to copy/paste, though). Also, you'll need to reimage your cRIO.
You should also check out the LabVIEW resources at http://www.usfirst.org/community/frc....aspx?id=10934 to help understand program flow, deploying and the different templates.
Russ
New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway LVMastery NI LabVIEW 3 28-01-2009 07:06
A few Labview questions Japper NI LabVIEW 14 09-09-2008 20:41
Questions about Hybrid Period and general rules... 354.FIRST Rules/Strategy 3 19-02-2008 00:58
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Some questions and answers... Joe Johnson Off-Season Events 0 26-10-2001 12:56
