Go to Post Actually, please don't put any limits on your ideas or creativity at this point. Brainstorm, innovate, and contemplate whatever ideas you might like to consider. - dlavery [more]
Unread 07-01-2009, 09:48
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Re: Our Team Needs Help on the Drive!
Originally Posted by Matt H. View Post
If you make your front wheels crab turning will be much more efficient. by turning your front wheels 90 degrees you will be able to turn on a dime--With this design I would still recommend you power your rear wheels independently to assist turning. This would make a killer design which could turn easily and maintain your design objectives. For this design I would use a CIM run through a custom gear box direct drive for each rear wheel. In the front I would use crab modules consisting of an upward CIM and a miter gear set up. Two FP motors would rotate the crap modules.
Well throwing another question out there that I have, for crab drive, I have never really seen one so I am not sure how they work or how to set it up. From my understanding this is what it would look like (correct me if I'm wrong)
|---\__/---|
|oo------oo|
_________
(This is not to scale, (-) is just a space so ignore them)
The circles (o) would be the wheels powered, and pointed to the front of the bot, the (=) would be wheels facing <- at a 90 degree angle, and powered. Is my interpretation of crab drive front wheels correct?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 07-01-2009, 10:30
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
[quote=dtengineering;794539]And we're thinking of something like:
__          __
|[]\_______/[]|
With the center wheels dropped a bit, but all wheels driven. Depending on where the centre of gravity is located it begins to approximate a two wheel drive as the majority of the mass will act through the centre axles. As one approaches this state the transverse friction on the wheels preventing skid steering should begin to approach zero.
Of course, building in the wide direction does present other challenges, but also presents other opportunities. We've never built a "wide" robot before, but this year's game has inspried us to try something new.
Jason
QUOTE]
This is the exact design that we are thinking of. We used this design on our 2006 'bot, and it worked great. Though the wheel layout was different in '06, I think that the new wheel layout will prove worthy. Now to see how it "slides" on the new floor...
Unread 07-01-2009, 10:47
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
It's interesting to see some convergence. These are the drive configurations for our two leading design concepts.
 One Wheel           Two Wheel
      _                  _
      _                  _
      O                  O
// = driven and steerable,  || driven fixed,  | and _  fixed freewheeling.
O = Trailer Hinge Pin
Design CG is over the single driven wheel for one wheel drive
and between the  two driven wheels for the 2 wheel drive.
Driven wheels are dropped so that the non-driven wheels
do not normally touch the ground unless external forces are in play.
Unread 07-01-2009, 14:13
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
|---\__/---|
|oo------oo|
_________
Not quite, but close
If the front two wheels are in a crab modules then they are free to rotate as directed by separate motors. i.e. when turning the crab wheels (=) would be exactly as depicted above, but when moving in a straight line the wheels would be parallel to the rear wheels. The wheels can be turned at a whim using two additional motors. Each crab module consists of a drive motor (generally a CIM) and a turning motor which turns the module.
Here are some threads and images better explaining crab drive:
http://www.chiefdelphi.com/forums/sh...ad.php?t=55454
http://www.chiefdelphi.com/media/papers/1836 (he calls crab swerve, but they are very similar)
Crab drives are a challenge to build, but can dominate if correctly implemented.
Unread 07-01-2009, 20:54
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay our team officially decided on the following:
______--------------______
|---0-----\_______/----0---|
|-----------------------------| ******28*******
|--00--------------------00--|
_______________________
********38*********
So the (0) is a wheel pointing forward only, and it is a tank drive. The width is on the side, and the longer side, in the back. All wheels are powered by one chain on either side, one motor on either side.
This was what I tried to get our team to do:
|---=-----\_______/----=--|
|--0----------------------0---|
********38*********
The (=) is a crab drive wheel and the back two wheels are just pointed vertically, all wheels powered. Each wheel would have it's own motor and chain moving it.
So if the first drawing is A, and the second one is B, then here are some questions:
1) Which drive looks better for this competition?
2) What are the pros and cons of A?
3) What are the pros and cons of B?
4) Suggestions that we should take under advisement, and any other comments.
TY to all who respond!
Ben Kellogg
Unread 07-01-2009, 21:12
The crab module will be better for the competition provided it is constructed properly and the programming is done correctly. However, the crab drive may result in disaster if things go wrong.
A is more easily constructed and will provide more time for driver training testing etc. It should perform almost as well as B.
B will be more maneuverable and better able to push in all directions; however it will be much harder to build, design, program.
If you have never constructed a crab drive I would recommend you build a tank drive as in A and try to design a crab module in the off season. Too much can go wrong during the build if you attempt to try something completely new in a single build season. Try to make what ever you decide the best it can possibly be. Oh and have fun.
Unread 07-01-2009, 23:02
Engineering Mentor
AKA: Wally Ritchie
<snip>
1. It depends on the location of the cg and whether the wheels are coplaner or some set is dropped. The trailer is effectively part of the robot.
2. See (1). What do you expect the doubled wheels to do for you?
3. See (1). What do you expect the crab wheels to do for you?
4. I believe that what the GDC is trying to do with this years game is to force teams to do the physics and math and understand all of the forces at work. They have effectively created an environment for which past rules of thumb and past experiences and intuition may not apply. But the laws of physics still apply. Use them to engineer your robot. As you get to understand the physics insights will start to appear.
OK, you have a couple of potentially viable configurations. Put the trailer in the picture. Stick the cg in some realistically attainable envelope and start calculating with the cg in the center of that envelope. What net force will the robot have? What turning moments will the robot have? Move the cg to the corners of that envelope and recalculate. Does it still work?
The traditional steps in evaluating design concepts are:
1) Does it work well on paper. If not, it still might work in the real world but it's usually not worth the risk. Engineers don't build things that don't work on paper (unless the're software engineers )
2) If it works well on paper, confirm that your assumptions and calculations are valid and that it is likely to work in the real world as well.
3) Is it feasible to complete in the allotted time, i.e. detail design, build, test, etc.
4) Does it meet all the requirements of your application (i.e.) your selected strategy?
5) Is it likely to be competitive? (in the commercial world this is often a life or death parameter. In government nobody cares. In FIRST everybody is a winner.)
It's still early. Do the math. If you need help with the physics or math just ask.
My Team Needs Help Scouting Orfrith Scouting 18 29-04-2007 00:48
Our team needs your help!! Seto Kaiba Team Organization 7 22-02-2006 07:44
Team 1646 needs your help for the 2005 IRI Turnaround Round (Mentors/Adults) D.J. Fluck Off-Season Events 7 19-07-2005 10:54
A Team needs help! archiver 1999 2 23-06-2002 22:57
