Re: Does the FRP material go over the carpet?
This might be wrong, but now we can put the carpet back down and glue/steam it next year (when we hopefully have carpet again on the entirety of the field) and not be out a lot of money. |
I'll chime in too.
On the Kickoff field in Manchester the Glasliner was just unrolled over the carpet and was taped down only along the outside edges with black gaffers tape. The three 8' wide rolls of Glasliner used were taped to each other with clear reinforced tape. The Glasliner did not conform to the carpet and lay flat all over. It rippled a little bit in the middle as we walked on it, especially the middle sheet. Probably not enough to bother the robots though. Last edited by Mark McLeod : 07-01-2009 at 15:07. |
I don't know if anyone has read Paul Copioli's post in the Team Update #1 thread but it might provide some insight/help in this one.
I should add that the FIRST field construction crew were not happy with the way the floor rippled a little on the Kickoff field. They plan to work with it some more to figure out the best way to keep it flat.
| Throwning the ball over the over Pass | eastsideboma | Rules/Strategy | 16 | 15-01-2008 12:56 |
| Building the field :: where can I get the carpet? | Armando Gonzalez | Technical Discussion | 10 | 12-01-2007 14:14 |
| Use for all the items in the Advance Material List | Bruce Newendorp | Kit & Additional Hardware | 0 | 09-01-2005 22:40 |
| What does your team do over the summer? | Jeremiah Johnson | General Forum | 12 | 10-05-2003 23:58 |
