Go to Post Corndog is the new water game. - Basel A [more]
Unread 05-01-2009, 18:29
EROCK EROCK is offline
FRC #2450
EROCK is an unknown quantity at this point
Working with spikes and servos in labview
Hello all the programming team and I are still getting used to this new labview environment and we can successfully get the 2.5 inch CIM motors to drive using jaguars but we would like to be able to assign a button to activate a spike controlling a servo. what must we do in lab view to get this to work or is it not even possible.
Unread 07-01-2009, 11:01
dlesley dlesley is offline
FRC #1915
dlesley is an unknown quantity at this point
Re: Working with spikes and servos in labview
You need to use the relay VI set from the WPI library. You can find those in the Actuator section. Look at the Relay Example in the LV opening screen. That should show you what needs to be connected where, and you can copy and paste pieces of it into your Main vi. For competition use, I'd recommend a case structure around the SET Relay VI, activated by an unbundled Button 1 from a Joystick GET, as well as changing any controls you can to constants.
Unread 07-01-2009, 11:38
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Can you clarify what you're trying to do? Servos do not get connected to Spikes.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
C and LabView version control with Git Nibbles NI LabVIEW 31 17-01-2010 19:22
Labview Servos quizbiz NI LabVIEW 5 09-01-2009 08:48
Labview NXT Servos quizbiz National Instruments LabVIEW and Data Acquisition 1 30-12-2008 14:42
First problems with FTC and Labview PhilBot National Instruments LabVIEW and Data Acquisition 0 10-09-2008 20:21
Are Spikes needed with servos? aksimhal Electrical 9 23-01-2007 20:27
