Go to Post I may be right or wrong but I’ll be happily senile doing it. - ebarker [more]
Unread 06-01-2009, 16:22
1120227 1120227 is offline
FRC #2338
1120227 is an unknown quantity at this point
Does the FRP material go over the carpet?
(We are assuming it does.)
Unread 06-01-2009, 16:26
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
Re: Does the FRP material go over the carpet?
I think The Blue Alliance video shows what looks to be an "edge treatment" for the FRP stuff, so it would seem that it is indeed above the carpet.
Unread 06-01-2009, 16:43
Steven092391 Steven092391 is offline
AKA: Steven
FRC #0034 (Rockets Robotics)
Team Role: Student
Steven092391 is an unknown quantity at this point
Send a message via AIM to Steven092391
According to a clip from the competition manual, I am led to believe that the playing field is constructed with the same type of carpet as it has been over the past several years, but is simply covered by the new "regolith" (or Glasliner FRP). I have included the particular clip from Section 6 of the 2009 manual.
I hope this helps you out!
Unread 07-01-2009, 10:00
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
Does the FRP material deform at all with the soft carpet underneath? Has anyone measured this?
Unread 07-01-2009, 10:03
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The carpet itself does not have enough give for the FRP material to deform. What the carpet gets put down on, however, could likely have an impact. Recall certain venues where the field gets built on top of plywood sheeting that is not always flat. However, I have no idea if this will or will not have an effect this year.
Wetzel
Viva Olancho!
Unread 07-01-2009, 10:05
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
From what I saw while walking on it at SNHU, it looked like the FRP was directly on the carpet. However, we didn't want to ruin our new carpet (bought it last year to replace the carpet that was down for 10 years), so we cut up the section where it was going and glued it down directly to the subflooring.
This might be wrong, but now we can put the carpet back down and glue/steam it next year (when we hopefully have carpet again on the entirety of the field) and not be out a lot of money.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 07-01-2009, 11:15
I'll chime in too.
On the Kickoff field in Manchester the Glasliner was just unrolled over the carpet and was taped down only along the outside edges with black gaffers tape.
The three 8' wide rolls of Glasliner used were taped to each other with clear reinforced tape.
The Glasliner did not conform to the carpet and lay flat all over.
It rippled a little bit in the middle as we walked on it, especially the middle sheet.
Probably not enough to bother the robots though.
Unread 07-01-2009, 11:48
Onward through the fog.
I don't know if anyone has read Paul Copioli's post in the Team Update #1 thread but it might provide some insight/help in this one.
~ Helen Keller
(1880-1968)
Unread 07-01-2009, 12:55
I should add that the FIRST field construction crew were not happy with the way the floor rippled a little on the Kickoff field. They plan to work with it some more to figure out the best way to keep it flat.
Throwning the ball over the over Pass eastsideboma Rules/Strategy 16 15-01-2008 12:56
Building the field :: where can I get the carpet? Armando Gonzalez Technical Discussion 10 12-01-2007 14:14
Use for all the items in the Advance Material List Bruce Newendorp Kit & Additional Hardware 0 09-01-2005 22:40
What does your team do over the summer? Jeremiah Johnson General Forum 12 10-05-2003 23:58
