Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Unread 07-01-2009, 12:55
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Digital Sidecar Problems
Hey Guys I think something is definitely wrong with both of our digital sidecars but wanted to get ur opinion.
We couldn't get our programs to work for three days with Labview. The example programs didn't even work! They downloaded by all the victor and jaguars had no signal. Turns out, after we removed the jumper next to the pwm pin for the servo, things magically started working. So we got everything to work except for the servos (since we can't connect the jumper else everything will not work). The watchdog timer light didn't turn on so it's not a software issues (especially since it works if we remove the jumper using the same program).
We also noticed through our trouble shooting that the BAT and 6V lights on the digital sidecar do not light up. Are they suppose to? Is the 6V suppose to light up with the jumpers (it doesn't)? But the 5V light is on.
Are both of our digital sidecars defective? Anyone else have this problem?
Unread 07-01-2009, 14:30
Re: Digital Sidecar Problems
Do you have the Digital Sidecar wired from the 12v waqo connector directly to the Power Distribution panel, with an associated 20A breaker?
How about if you take a close up photo of the Digital Sidecar all wired up and post it for us?
Unread 07-01-2009, 15:12
#0368 (Kika Mana)
We're not going to be going in to the shop today so I'll have to post a picture tomorrow, but I can describe how things are wired to the digital sidecar.
18AWG, 12V from wago connector connected to 20A breaker on power distribution pannel.
DB37 Cable from cRIO to digital sidecar.
Pwm 1 & 2 connected to jaguar
Pwm 3 & 4 connected to victor
Pwm 5 connected to servo, jumper installed (also tried Pwm 8 and 10 same resuts)
Pwm installed according to pinouts as shown on digital sidecar.
Thanks for the help!
(Also posted on FIRST forums in case we actually do need a replacement and it's not a solvable problem)
Unread 07-01-2009, 15:22
The connections sound correct.
It's very strange though that you'd happen to get both defective Digital sidecars.
With the lack of Batt and 5v status leds I'd suspect the 12v power feed from the distribution panel.
When you tried both side cars did you use the same power cable?
An immediate suspect is that the wago clamps at one end or the other are grabing insulation rather than wire.
Try pulling the 20a breaker (leaving the power distribution wago connections alone) and testing continuity of that cable with a meter.
After testing try removing the wire from both wago connector ends and reattaching them.
Unread 07-01-2009, 15:28
#0368 (Kika Mana)
Yup, both sidecars having the same problem seems wierd unless it's a manufaturer defect. But then I would expect more teams to have the same problem (we got ours as part of the early ship-early dec).
When we did try the two we used the same power connection. We'll try a different breaker/wire and see what happens.
What's strange is that when we take out the jumper, the Bat light still stays off (5V on) but everything still works.
Unread 07-01-2009, 15:34
The PWMs for the speed controllers don't use the 12v power. That's just for the servos, digital I/O's, relays, I2C.
So it's not surprising that they work without the power line. The DB37 must feed enough power for the basic sidecar circuitry.
It is interesting that the jumper stops them from working. I'll try pulling the plug on ours tonight and seeing if we get the same behavior with a jumper.
Unread 07-01-2009, 15:37
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Make sure that you don't have the power leads swapped. The 5V light may be getting a very small amount of power via leakage from the DB37 through the PWM driver ICs.
Russ
Unread 07-01-2009, 15:43
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I would highly recommend you unplug everything for the Digital Sidecar. Then just provide 12v power and make sure the the three LED's turn on. Then connect the DB-37, then add a jumper, then start connecting the PWM cables. I think you might find a short in your wiring for the PWM cables.
Unread 07-01-2009, 15:53
I have a feeling that Russ is right with his "reversed power plus leakage" theory. Since adding the load of a servo kills the board entirely, you might have a very weak power path.
The BAT LED has an under-voltage detector. Since it is not on, it is indicating that it needs more voltage to properly run. Negative voltage also fails to turn on the LED.
I couldn't find your post on the usfirst.org site. Can you link?
Unread 07-01-2009, 16:57
#0368 (Kika Mana)
I was so curious I had to drive down to the shop to figure out this problem right away. So....
Russ
I had no clue that power from the cRIO was able to feed the pwm cables. Turns out everything was wired to their correct place. But after pulling out the power from the power distribution board, looks like the Gnd connecting was clamping on to the insulation rather than the wire! ( we'll have to be more careful next time) So...no power to the digital sidecar!
After fixing the wire, all three lights go on. YAY!
Thanks Russ and Eric for helping us out!
Unread 07-01-2009, 17:16
I should have also mentioned about the insulation pinching. I've done that one myself. It's obviously important to make sure that you expose enough wire.
Glad to help!
Russ
Unread 31-01-2009, 14:45
infiniteloop infiniteloop is offline
FRC #1014
infiniteloop is an unknown quantity at this point
We opened up our sidecar and examined the circuit board; we found that the C6 capacitor was not soldered to both pads. Has anyone else opened up their sidecar and examined the circuit board?
Unread 31-01-2009, 14:47
FRC #1014
Oh, I should add that 2 of our 3 sidecars have this defect.
Unread 31-01-2009, 17:23
Breaking C6 is a known problem that shouldn't cause any problems.
Russ
Fusing for Digital Sidecar (was: HIZZELP) KilroyLaxer FRC Control System 4 15-12-2008 20:44
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Missing Standoffs on Sidecar psyco_klown Electrical 3 03-12-2008 19:40
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
