Go to Post DO NOT THROW THINGS AT THE PROGRAMMER! - demosthenes2k8 [more]
Unread 07-01-2009, 15:35
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Question Basic functions in windriver
I've searched, and searched but I just frustrate myself more. I can't see to find out how to do a few basic things I was able to do in MpLab on the old control system. I don't know how to use WPILib to my advantage just yet, and through all this complexity I just need to know how to do a few simple things!
First off, how would I go about writing code for a joystick in which an axis controls the speed of the motor?
how would assign a joystick to a pwm? (Same as above pretty much)
how would I invert a motor in code?
where can I find out what variables I can use for C++ in Windriver?
How do I program a button?
In most posts people have been directed to the FRC control systems page, but I don't see anything helpful. Maybe i'm missing something, but if anyone could show me some sample code or pass some links to show me the right direction I would be eternally grateful. And if you're really in the mood to help, maybe you everyone could throw in some extra bit with other "simple" functions that people could reference from this post.
Thanks in advance!
-Rameez
ahhh Division Finalists!!
Unread 07-01-2009, 16:14
Bharat Nain's Avatar
Re: Basic functions in windriver
http://first.wpi.edu/Images/CMS/Firs...de_for_FRC.pdf
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 07-01-2009, 16:17
Meezy the Mentor
AKA: Rameez
there's too much information to grab from that, and I honestly haven't be able to grab too much use from it...
Unread 07-01-2009, 19:43
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Why has WPI not released proper documentation yet? That PDF is from October, it still has the DRAFT watermark, and is littered with incomplete examples and napkin CAD, which is extremely frustrating when adjusting to the new API.
Looking at the internal source code has helped some, but many things are still unclear, and the manual could use a glossary for terms related to the cRIO and its new modules..
Don't get me wrong, i highly appreciate what they are doing and they've done quite a bit in a (relatively) small amount of time, but it all feels rather rough around the edges.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 07-01-2009, 20:19
Meezy the Mentor
AKA: Rameez
I feel the same exact thing. Every time I get to something that could possibly help me, it's still incomplete. I either need that manual complete, or some nice person to post lines of example code that is specific to what I'm asking for. ...
I spent a few hours reading through code and testing random things, and I taught myself something that someone could've showed me in two minutes.. Can anyone please help me/us out?
-Rameez
Unread 08-01-2009, 01:13
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Have you looked at the example template things that they have in windriver? They show a couple of decent examples.
I haven't been able to actual put code on our controller yet, but I have been playing with the code a bit (I don't know if what I wrote works yet ) so I can't help too much yet
From what I have looked at it looks like there are a couple of ways to go about the basic drive functions. You need to create your joystick objects
Joystick LeftStick(1);
Joystick RightStick(2);
then either create a RobotDrive object or create motor controller objects (or both)
Jaguar LeftMotor(1);
Jaguar RightMotor(2);
then set the speed to the joystick
LeftMotor.Set( LeftStick.GetY() );
RightMotor.Set( RightStick.GetY() );
The only problem is that I am not sure if Joystick::GetY() returns a scaled number between -1.0 and 1.0 that I think the Jaguar.Set() takes, otherwise there is the RobotDrive function which is shown in the simple robot sample example template thing
Hope that helps
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 08-01-2009, 07:43
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
The Joysticks do return a value from -1 to 1, so you can put the values directly into the Jaguars.
If you were looking for a drive system off of one joystick you would use something like this. This could basically is a copy of the old code just usable on the new brain.
NOTE: In the code this year it seems to be easier to just declare all the variables you are going to be using as pointers. This code has also not been completely tested but it should work.
For global variables
Joystick *controller;
Jaguar *LeftMotor, *RightMotor;
In your constructor
//This creates a new joystick object to usb1 from the drive station
controller = new Joystick(1);
//Sets the left motor the pwm out 1 and right to pwm out 2
LeftMotor = new Jaguar(1);
RightMotor = new Jaguar(2);
You will need to put this function in the code. All it does is makes sure that the values given to the Jaguars are valid;
float valid_value(float value)
	if(value > 1)
		return 1;
	if(value < -1)
		return -1;
	return value;
Then finally in the teleoperated function you would use
LeftMotor->Set(valid_value(controller->GetX() - controller->GetY());
RightMotor->Set(valid_value(controller->GetX() + controller->GetY());
Now, if you want to grab button states from the joystick there are two ways to do this. In terms of this example i will use the controller variable declared above.
controller->GetRawButton(4);
controller->GetButton(Joystick::kTriggerButton)
Both lines return a simple bool state
The first example though returns the state of the button on the controller labeled 4. The second one shows how to use the GetButton function using the constants from the Joystick class.
If you would like to see all the classes in the new code with your project open in windriver look for the project explorer. Inside the project explorer hit the plus next to includes, then look at the files that appear then click the plus next to the one named C:\windriver\vcworks-6.3/target/h/WPIlib
Hopefully that cleared up alot.
Debug Windriver issue..... programmr C/C++ 12 06-02-2011 13:47
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
compiling in windriver koreabell Programming 4 05-01-2009 15:32
windriver projects nickmagus Programming 4 01-12-2008 23:29
