Go to Post Call it confidence, call it ego, call it what you want, but the fact of the matter is you need to be humble or someone will humble you. - Dan Richardson [more]
Unread 07-01-2009, 16:37
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
what are the trailer dimensions?
Dimensions such as diameter, the height of the rod in the center, and the height of the rods on the circumference....I couldn't find it so figured I would ask.
Unread 07-01-2009, 16:42
Electrical Engineer
Rookie Year: 1995
Re: what are the trailer dimensions?
I would start by looking at section 6.4 of the manual.
Mike Betts
As easy as 355/113...
Unread 07-01-2009, 16:43
AKA: Brandon Liatys
I looked through the manual and couldnt find it....but now that you pointed out the specific location I might be able to. Thanks!
Unread 07-01-2009, 16:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Also, for specific Trailer drawings info:
http://usfirst.org/community/frc/content.aspx?id=11624
And to build a low cost version of the Trailer for testing:
http://usfirst.org/community/frc/content.aspx?id=11626
Trailer Tongue? Are they COTS? neoshaakti Kit & Additional Hardware 5 09-01-2009 17:51
If the trailer you are attached to tips over... Elgin Clock Technical Discussion 5 06-01-2009 15:29
dimensions for trailer jblay General Forum 2 06-01-2009 10:54
trailer dimensions mackfix General Forum 2 03-01-2009 20:21
