Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 07-01-2009, 17:26
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Are six wheels better than four?
Originally Posted by squirrel View Post
I suppose someone who wants to use an extra wheel for instrumentation could calculate how much force it needs to contact the floor with, to prevent it slipping under maximum robot acceleration conditions (it would slip if it takes more torque to overcome it's own inertia, than will be transfered to it by the frictional force of it's contact with the arena). I expect it won't take (much) more than it's own weight.
The point being, any normal force used to creating friction between the instrumentation wheel and the ground is normal force that's not able to be used to create friction between the drive wheels and the ground.
On a different note:
Our team is still considering different drivetrain options, but we've nearly decided on a six-wheel, dropped center wheel method if we follow a differential drive design, as the ability of the robot to rock slightly will allow the robot to not be as affected by transverse friction when trying to turn. We've tested a 4-wheel differential drive and while accelerating was not as difficult as one might think, turning was not as responsive as we would like. We're waiting for two more rover wheels to test out the 6-wheel drive.
--Ryan
FRC 766, 2015-, Mentor
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Bad Weather - Better Now than Later archiver 2000 33 24-06-2002 00:39
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
Chief Delphi 7 Picture -- better than nothing Joe Johnson Robot Showcase 7 02-03-2002 18:55
