Re: jaguar brake\coast controlling
Per <R60> if you want to wire the Brake/Coast Jaguar input, you must do so directly to the Digital I/O of the DSC. In this case, you should use a SINGLE wire between the signal of the DSC and the middle pin of the CB header (and only a single wire). To connect any other wire invites shorting unequal voltage sources or introducing additional current return paths.
| Victor Brake/Coast Default | FRC4ME | Electrical | 7 | 31-03-2008 13:40 |
| Brake / Coast switching for Victors | nreyesciena | Control System | 2 | 28-01-2008 13:17 |
| Victor 884 Brake/Coast Issues | sciguy125 | Control System | 23 | 23-01-2005 14:46 |
| Speed Controller brake/coast setting | steven114 | Electrical | 21 | 03-03-2004 13:05 |
| Brake/Coast Jumper | archiver | 2001 | 3 | 24-06-2002 01:04 |
