Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 07-01-2009, 18:07
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Benchtest Jumper Question
In section 3.4.1.2 of the Control System datasheets, where should the jumper be placed for the benchmark test? I am referring to the power selection jumper on the analog breakout module.
Compiling...
Compiling...
Unread 07-01-2009, 23:09
Re: Benchtest Jumper Question
The jumper on the Analog Bumper in Slot 1 goes on the middle and outer pins. In the diagram in section 3.4.1.2 jumper the two pins at the very top of the diagram together. This pipes the 12v robot battery voltage into analog input #8 and the default (not OTB) code displays the battery voltage on the Driver Station.
The jumper on the Analog Bumper in Slot 2 goes on the middle and inner pins, so you can use that analog input #8 as a normal input.
Can i still benchtest without OTB version? programmr FRC Control System 7 16-12-2008 20:52
Ordering a center jumper BQuennell Electrical 3 27-02-2007 15:08
PWM 2 pin jumper mechanicalbrain Electrical 4 18-12-2005 18:09
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
broken jumper on controller Mike Soukup Technical Discussion 5 22-10-2001 20:49
