Go to Post so this is going to sound really dumb but remember that i am a mechanical guy. - Greg Needel [more]
Unread 29-12-2008, 14:15
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
Re: Getting Familiar with Programming in WindRiver
Thanks both for the replies.
So in order to pull information from the HID joysticks, it has to be pure P&P that doesn't require any drivers whatsoever? So, if we find such as device, everything else should be preconfigured? For example, for a steering wheel, the wheel provides x-values, and the pedals provide the y-values? Or is there anyway to preset specific functions to specific buttons or features of the joystick?
Unread 29-12-2008, 15:28
koreabell koreabell is offline
Team 956 Safety Captain
FRC #0956 (Eagles)
koreabell is an unknown quantity at this point
most of joysticks come with drivers when you buy, but that doesn't mean you necessarily need that driver.
if you plug the joystick into the driver station, it'll most likely recognize the device without driver(unless the joystick really need driver).
you'll need WPILib to get information of joystick status, which can be interpreted as it is preconfigured.
you can assign specific functions to corresponding buttons by making if or switch case statements.
for example
	int button[13]; // find which button is pushed
	int a = 0; //how many buttons are pushed?
	for(int i = 0; i < 12; i++){  //Get what button(s) is/are pushed and save it in array variable
		if(Joystick::GetRawButton((i+1)) == TRUE){
			button[a] = i;
			a++;
	for(int i = 0; i < a; i++){
		switch(button[i+1]){
			case 0:  //if nothing is pushed
				break;
			case 1:  //if button1 is pushed
				DoThis();
				break;
			case 2:  //if button2 is pushed
				DoThat();
				break;
			case 3:  //if button3 is pushed
				DoThese();
				break;
			case 4:  //if button4 is pushed
				DoThose();
				break;
			case 5:  //if button5 is pushed
				DoIt();
				break;
			case 6:  //if button6 is pushed
				GoThere();
				break;
			case 7:  //if button7 is pushed
				ComeHere();
				break;
			case 8:  //if button 8 is pushed
				Shoot();
				break;
			case 9:  //if button 9 is pushed
				RunAway();
				break;
			case 10:  //if button 10 is pushed
				Stop();
				break;
			case 11:  //if button 11 is pushed
				DisableYourself();
				break;
			case 12:  //if button 12 is pushed
				AbortAndCatchOnFire();
				break;
	a = 0;
	for(int i = 0; i < 12; i++){  //reset
		button[i] = 0;
i think you can have up to 12 buttons and i doubt you'll assign all 12 buttons to its corresponding functions but that's one way to do it.
the other way is having a lot(depends on how many buttons you'll be assigning specific functions to) of if and else if statements
there might be other ways but I can't think of it at the moment
Unread 31-12-2008, 14:29
Software Specialist
AKA: Daniel
VRC #0646
I see... Since there are 12 programmable buttons, I'm guessing that either the standard joystick is labeled or there's a diagram showing what button corresponds to what... But what if we use a different joystick? Do we have to test which buttons match which input source?
Unread 31-12-2008, 14:51
FRC #0956 (Eagles)
most of the joysticks have number on each button, maybe except for trigger button and, if you're using logitech joystick and cannot figure out which button is which, install logitech gaming software that came with the joystick(to computer), execute it with joystick plugged in to one of the computer's usb ports, and start pressing buttons. the program will tell you what button you're pressing.
i don't know if other companies support those kind of software or not, but if you have logitech joystick, you can figure out that way
if you're making your own usb joystick, then you'll have to label it as you make it, but if you're buying joystick, then i wouldn't worry too much about not knowing which button is which
btw, if you want to test without robot or drivestation, run joystick-playable game and go to key configuration(or something like that), and try changing joystick key. it'll show you which button you pushed after you assign a key (for most games)
Unread 06-01-2009, 09:33
Software Specialist
AKA: Daniel
VRC #0646
Thanks for the reply. You've been really helpful ever since I posted this thread.
After much thinking (upon watching the game), I think we've made the decision to go with the USB joysticks that we're given standard to our team (Logitech ATK3).
Right now though... I have another problem that has been giving me major problems. Aside from not being able to get our camera correctly connected and configured when it's plugged into the cRIO... I'm not quite sure how I'm supposed to program it to track colors or shapes in WindRiver. Do I do so with pure code or is there another utility that helps monitor that? And of course... How am I supposed to implement that into the code.
Secondly... Right now, the only way I've gotten the motors to move is through the RobotBase class. Is there any other way to control a specific motor (whether it be Jaguars or Victors) a specific speed? The functions in WPIlib.h only tells you what speed you want to set it to... but there are no parameters that reference the PWM port the motor is plugged into...
Unread 06-01-2009, 16:40
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The PWM port is specified as a parameter to the constructor.
I think I read where the WPI guys are putting out an update to the camera classes (in the next few days) that works. How to use the data from the camera to guide your robot or dummper (or whatever) is up to you.
Unread 07-01-2009, 11:25
Software Specialist
AKA: Daniel
VRC #0646
Mmkay... I think I kinda get what you're saying... But just to clarify... How would you get a motor on PWM1 to go half speed for 2 seconds and PWM2 to go full speed for 3 seconds?
As for the camera classes... Do we check back on the FIRST website or the WPI site?
Unread 07-01-2009, 11:41
erikstotle's Avatar
erikstotle erikstotle is offline
Quendi
AKA: Erik
FRC #0107
erikstotle is an unknown quantity at this point
Send a message via MSN to erikstotle
Btw, in c++, you use -> to access elements of a class by pointer, and . to reference elements by refrence. I remember that concept always confusing me when I started out with OOP...luckily Visual Studio's Intellisense complains at you when you use the wrong one, so I learned quick enough .
Unread 07-01-2009, 15:41
Software Specialist
AKA: Daniel
VRC #0646
Thanks for clarifying that up for me.
Unread 07-01-2009, 17:22
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
How do you open a new C++ file with WindRiver?
How do you open a new C++ file with WindRiver? I've already downloaded the FIRST version and it is working but I do not know how to actually make a new program. Thanks for the help.
Unread 07-01-2009, 19:34
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: How do you open a new C++ file with WindRiver?
Do you mean to ask how to create a new source file in an existing project?
Or did you mean to ask how to create a new project?
Unread 07-01-2009, 20:08
FRC #2589
I have already set up WindRiver and the "MyRobot" template is set up but I don't know how to set up new source code files for my own robot code. I can't find it in the directions and I don't know what to do. Thanks
Unread 07-01-2009, 20:19
Software Specialist
AKA: Daniel
VRC #0646
Err... To do this go to File -> New...
And then select the project that you want. From there on the bottom there's a textbox where you type your file name WITH the extension. For example... If you want a C++ source file named test... then type in test.cpp. If you want a header file... for example, testlib... then type in testlib.h.
It should automatically create a file in the project that you selected.
Unread 07-01-2009, 20:22
FRC #2589
Oh ok thanks
Unread 07-01-2009, 20:32
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Right-click on the project to which you want to add the new file.
Select New->File from Template.
The New File dialog will appear.
Type in the new file's name.
Click the Change... button.
A Preferences dialog will appear -- here you'll select 'cpp_template'.
Click OK in the Preferences dialog.
Click Finish in the New File dialog.
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Help Getting Started with VEX programming. Joe Johnson VEX 5 16-04-2007 09:01
pic: Mobot with familiar parts jgannon Extra Discussion 11 24-04-2006 18:55
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
