Go to Post "It doesn't matter what you think happened, what the Ref calls (or doesn't) is what happened. The judgement of the Ref is part of the game, live with it or don't play." - ChrisH [more]
Unread 12-10-2001, 01:19
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
Question fischer price motors
does anybody have the specs for the fishcer price motors or know where i can get them. specifically the amount of current they draw.
-Paul
Unread 12-10-2001, 08:31
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
White Papers......
You might want to look under the White Papers for something on motors....
maybe the "FIRST Motors, Etc. (spreadsheet)" on the first page could help....
Purdue Alumni
Cummins, Inc.
Unread 12-10-2001, 08:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Going From Memory...
From my memory, I think the stall current is somthing like 60 Amps. The free speed is 15K RPM. The stall torque is .3 N-m.
The spread sheet will have the true numbers, but the above numbers are prettty close.
Joe J.
Unread 12-10-2001, 08:50
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Post Fisher-Price motor spec...
From the 2001 FIRST Robotics competition Manual, Robot Appendix: H Part specifications...
Can be found at http://www.usfirst.org/2001comp/Docs/
"The Robot - Part 4"
"Fisher-Price motor information
The following are approximate performance data for the Fisher-Price motor/gearbox sets supplied in the kits. The motor used is a Mabuchi model RS-550PF-6534.
Motor no-load speed 15,000 RPM
Motor stall current 57 A
Motor stall torque 0.363 N-m
Gearbox ratio 147:1
No-load speed w/gearbox 100 RPM (estimated)
Stall torque w/gearbox 34.7 N-m (estimated)"
Unread 12-10-2001, 09:44
The direct link to the spread sheet is: http://www.chiefdelphi.com/forums/pa...per&paperid=15
The fourth sheet has data for all the motors. The first three let you input the data about a specific motor and get plots for the power, efficiency, speed, etc with respect to torque.
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
Fischer Price Motor help needed archiver 2000 10 23-06-2002 22:07
Fischer Price Part Number? bmusser Technical Discussion 0 02-02-2002 12:26
