Go to Post When I mentor other people in programming... they either get pointers or they don't. - JamesTerm [more]
Unread 07-01-2009, 17:47
mynameisbob's Avatar
mynameisbob mynameisbob is offline
Electroblaster
FRC #2422 (Bucket-o-bolts "BOB")
Team Role: Electrical
mynameisbob is an unknown quantity at this point
Send a message via Yahoo to mynameisbob
cRIO fuse??? 20 or 30?
Im probably an idiot and not reading the right part of the manual, but what fuse should I use for the cRIO 180 pwm thingey? I know I have the wiring and everything right, but ive no clue of the right fuse to use.
Bucket O' Bolts
team 2422
My name is BoB!
http://www.bucket-o-bolts.com
"Its better to be thought an idiot than to open your mouth and remove all doubt!"
Unread 07-01-2009, 17:51
Re: cRIO fuse??? 20 or 30?
I do not know what you mean by "cRIO 180 PWM thingey". What does the label on the module say?
Unread 07-01-2009, 20:58
LeadCoreWarrior's Avatar
LeadCoreWarrior LeadCoreWarrior is offline
OCD Wire Monger/Project Manager
AKA: Gabe Ochoa
FRC #0418 (LASA Robotics/Purple Haze)
LeadCoreWarrior is an unknown quantity at this point
Send a message via AIM to LeadCoreWarrior
The cRIO does not need a fuse. At the end of the Power Distribution Board (PDB) opposite the main + and - terminals there is a place for dedicated 5 volts and 12 volts which are to be used for the camera and gaming adapter and a dedicated 24 volt plug that fits the same plug that also plugs into the cRIO for power. This is where you should be powering your cRIO from and it does not need a fuse. The wiring instructions for the cRIO as well as the rest of the control system can be found on usfirst.org under Control System Documentation, not under the game rules.
2008 Overdrive Operator
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction." ~Albert Einstein
Unread 07-01-2009, 21:22
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
are you talking about the sidecar?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 07-01-2009, 21:46
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
is not very descriptive. The cRIO itself goes to 24v without a fuse as i can tell.
http://usfirst.org/uploadedFiles/200...%20diargam.pdf
http://usfirst.org/uploadedFiles/200...%20diagram.pdf
Unread 08-01-2009, 09:00
Keen, Sean, and Lead -
Thank you for trying to help bob.
However, I must ask you to be careful in this instance. There is a very good chance that bob has not read the appropriate materials, and is therefore much more likely to damage his control system. In the future, please answer questions of this nature with direct hyperlinks to the appropriate section of the manual, with a page number or range included.
Thanks!
Unread 08-01-2009, 12:19
Racer26 Racer26 is offline
Your cRIO definitely should be plugged into the fuseless (well, I believe its internal to the PD board, but that's irrelevant) 24V port. The sidecars, and breakout boards should be fed a 12V supply from one of the PD board's many other outputs, through a 20A Snap Action circuit breaker. Other than that, you should not be applying 12V to anything attached to the cRIO. I suspect you're referring to the Digital Sidecar (it attaches to the cRIO with a large DB-37 cable). It provides the familiar PWM outputs to connect to speed controllers. It should be fed 12V from a 20A circuit breaker.
Unread 08-01-2009, 16:03
Electroblaster
Thank you guys for helping me, and yes, i am talking about the sidecar. I knew everything but the right fuse to use.
Bucket O' Bolts
team 2422
My name is BoB!
Unread 08-01-2009, 16:16
seanl's Avatar
i don't think that the manual says anything about the fuse on the side car, but i would use the 20 amp because the sidecar probably wont pull that much amps, and in the past we have used 20 amps on the old contollers. so you should be fine with a 20 amp.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 08-01-2009, 16:57
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
From the data sheet, available in chapter 3 here: http://usfirst.org/community/frc/content.aspx?id=10934
3.5.2 Typical Application
** Always refer to FIRST rules for using this module in competition robots. The following sequence
describes an example application that may not fully comply with FIRST rules.
1) apply power to the DSC via J22 from a 5A (or larger) breaker on the PD
2)[...]
This typical application uses a 5A breaker... i doubt you'll need 30A for a FIRST robot.
Also, the worst that can happen if you use too small of a breaker - the breaker pops, and you put a bigger one in, after determining that it didn't pop due to a short or other hazardous electrical condition. The worst that can happen if you use to big of a breaker - your digital side car, and possibly anything attached to it, could go up in smoke.
Unread 08-01-2009, 20:32
Try to keep in mind that circuit breakers are intended to protect the wires, not the components. If the Digital Sidecar itself pulled enough current to smoke something, it was probably already broken.
Unread 08-01-2009, 20:59
Electroblaster
Thank you guys, I have connected it and now it works fine. I think this new controll system is awsome, and I cant wait to learn all of the capabilities. Now I just got to look at our selection of sensors. I have made a test panel with a moter, basic pneumatic circuit, and all the electronics ecxept for the sensors, I want to make something for them too on the board as practice for our programmers while everyone else is working on the robots.
Bucket O' Bolts
team 2422
My name is BoB!
Unread 09-01-2009, 11:33
Mentor, LRI, MN RPC
Yes, but burning out a wire isn't the worst that can possibly happen I find with the students it's always best to start with the absolute worst, then back into the most likely worst case - it causes them to be a little more cautious when working on the robot, which keeps things neat, clean, and safe.
Spike fuse JanTM1191 Electrical 3 31-01-2008 23:02
Fuse Blow Zultraranger Pneumatics 1 25-01-2008 22:28
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Need RC Fuse Yan Wang Electrical 3 03-02-2003 22:06
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
