Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Unread 06-01-2009, 18:37
prashil27 prashil27 is offline
FRC #1727 (REX)
prashil27 is an unknown quantity at this point
Jaguar Motor Controller Problem
Hello everyone,
I am having a little technical problems with one of the jaguar speed controller and not sure whats wrong with it.
when I connected jaguar with the Sims motors its not getting any current to the motor. I follow the power distribution diagram and all the connections seems fine.
When I moved the motor forward with joystick it shows the red light and when its neutral its green light.
So I am not really sure whats going on there, any suggestions or advice will be greatly appreciated.
Thank You.
Unread 06-01-2009, 19:45
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Jaguar Motor Controller Problem
You might want to try and check the trims on the joysticks
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 06-01-2009, 20:36
FRC #1727 (REX)
ya i checked the joysticks and there is nothing wrong with it
Unread 06-01-2009, 23:00
Racer26 Racer26 is offline
Sounds to me like the lights are working... have you stuck a multimeter on the volts setting across the motor output leads on the Jaguar? You will get weird results at anything but full power, but at full forward, you should measure ~12V across them. If you dont see voltage there, your Jaguar is likely pooched, if you do, then its likely your motor that's pooched.
Unread 07-01-2009, 17:50
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Check http://www.luminarymicro.com/jaguar for more detailed information.
The LED status is as follows (not all conditions recreated here..)
Fast flashing yellow means you're NOT getting a valid signal on the wire. If you've got this, check your code or your wiring.
Solid yellow means you're getting a valid signal on the wire and that it is in the neutral range, and should produce 0 V on the output.
Fast flashing green means that you are going forward, and should produce between 0 V and 12 V.
Solid green means that you're at full forward, and should produce 12 V on the output.
Fast flashing red means that you are going reverse, and should produce between 0 V and -12 V.
Solid red means that you're at full reverse, and should produce -12 V on the output.
Output voltage measured across M+ and M- (white terminal to green).
Also, check your limit switch jumpers are both installed (up and down orientation.. see web site for documents).
Your report says that it goes to green light.. this could be characteristic of an untrimmed USB controller (joystick). Are you using the KoP joysticks? They self trim at start up so be careful not to be touching them during the power on sequence.
If you unplug your PWM cable, you should see a flashing yellow light.
Do you have anything mounted in parallel with the Jaguar? I.e. are you splitting the PWM wire and then putting one branch to a Jaguar and another to a Victor or something like that?
Unread 07-01-2009, 21:21
FRC #1727 (REX)
No, I don't have anything mounted parallel with the Jaguar and I m also not using victor, but I'll double check the led lights and see whats exactly wrong with it.
And thanks for the link that really answers a lot of questions!
problem with speed controller gaby1367 Electrical 11 14-05-2007 22:16
Controller problem, asap.. Max Brin Technical Discussion 2 20-02-2006 22:21
Speed controller Problem fixer upper Andrew Rudolph Control System 2 21-02-2005 08:22
Controller Problem doyler Programming 17 18-02-2005 22:01
Victor controller problem llambele Technical Discussion 3 14-11-2001 23:00
