Go to Post I voted to keep Stop Build Day but only for students. Mentors get to keep working on the robot. - marshall [more]
Unread 07-01-2009, 20:07
tubeheaD37 tubeheaD37 is offline
FRC #2079
tubeheaD37 is on a distinguished road
Control System Update Problem
Well, our team has encountered a slight problem while updating. Well, not a small problem. It won't update! We have tried many a solution to this problem after thoroughly searching the Chief Delphi database on the issue. Here is what is happening.
1) We plug in the USB drive.
2) We power it on in enabled and autonomous (we tried every other combination)
3) We held the buttons and accomplished the idiot test.
Here is where we experienced the problem:
After holding the Select button for the duration, the screen only flashes for a 1/4 of a second: "Do not turn off power - process takes several minuets - checking file size".
Anyone have a solution to our frustrations?
Unread 07-01-2009, 21:35
Geekzilla201 Geekzilla201 is offline
Alumni/Volunteer
no team (Bob's Builders in Black)
Geekzilla201 is an unknown quantity at this point
Re: Control System Update Problem
I had the same problem today as well. I was able to fix it by using a different flash drive. Try that and see if it works. Also, verify that you have renamed the file correctly.
Computer Science House - Rochester Institute of Technology
Unread 10-01-2009, 11:08
s0crates s0crates is offline
s0crates is on a distinguished road
What usb drive are you using?
Unread 11-01-2009, 19:22
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
yeah ... i had the same problem ... you should rename the auto run files and it will work
Unread 11-01-2009, 19:34
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
We're having trouble downloading robot code to the cRio after flashing the cRio with the latest update. We've seen the note with this update that you need to be careful because the cRio won't respond to downloads from PCs using the update if the cRio is still running the old firmware and we think this is the problem. We want to check this theory by looking at the version, build, etc. information sent to the console.
If we have successfully flashed the cRio, how would we know this by looking at the cRio boot messages sent to the console? In other words, what version numbers or build numbers should we see?
Unread 11-01-2009, 20:04
mahmosh's Avatar
FRC #1946
you should use upgrade v7.... you have to download the file named : FRCLabVIEWUpdate2.0
from this link http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
install it and then upgrade the crio by FRC cRIO Imaging Tool
if u didn't find it so tell me i may i can help you
Unread 11-01-2009, 20:42
For Update 2 look for a line that says:
FRC_NetworkCommunication...SVN revision 1510
New Control System Update Problems NinJA999 FRC Control System 3 29-12-2008 23:04
**FIRST EMAIL**/Control System Software Update Reminder Mark McLeod FIRST E-Mail Blast Archive 13 30-11-2008 21:05
**FIRST EMAIL**/ FRC 2009 Control System Early Release Update dlavery FIRST E-Mail Blast Archive 12 15-10-2008 19:30
Important IFI Control System Update Kevin Watson Control System 5 25-02-2004 23:31
Control system update RebAl Electrical 1 26-12-2002 22:36
