Go to Post For any coaches weary of choosing human players this year because you're worried they might lose their cool mid-game, a good indicator of someones ability to keep focused is their attitude while playing video games. - BradMello [more]
Unread 06-01-2009, 21:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Are six wheels better than four?
Originally Posted by Hachiban VIII View Post
Unpowered idlers of any type are a horrible waste of normal force.
In most cases, yes. However, this is a special case, in that the wheel does not need to support any of the robot's weight, it is being used only for instrumentation. If the speed sensing wheel is attached to a hinged arm, and carries only it's own weight, then it should not affect robot performance noticeably.
Unread 06-01-2009, 21:36
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
Driven (motor is powering the wheel) wheels will provide forward force.
Undriven (not powered by motor) wheels will distribute the weight more.
Traction depends on pounds per square inch of wheel that is in contact with the ground.
For example: you have 4 wheels, one in each corner. Robot = 120lb. Assuming that the robot is perfectly balanced, each wheel is carrying 30lb.
Example 2: 6 wheels, three on each side (left/right) with a 120lb robot gives 20lb per wheel.
More drive wheels still decrease weight/area ratio, but make up for it (possibly) with the added power.
Eschew obfuscation.
"I never enter into a battle of wits with an unarmed person. Therefore, I cannot fight."
Unread 06-01-2009, 21:46
run the trap!!!
Team Role: Human Player
Fat lot of good it will do as an encoder if it isn't pushing on the floor with significant force. If it slips, it won't be sensing anything meaningful.
-Philip J. Fry
Unread 06-01-2009, 21:58
MrForbes's Avatar
AKA: Jim
I suppose someone who wants to use an extra wheel for instrumentation could calculate how much force it needs to contact the floor with, to prevent it slipping under maximum robot acceleration conditions (it would slip if it takes more torque to overcome it's own inertia, than will be transfered to it by the frictional force of it's contact with the arena). I expect it won't take (much) more than it's own weight. I haven't done the calculations....I'll leave that for the students
Unread 07-01-2009, 17:26
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
The point being, any normal force used to creating friction between the instrumentation wheel and the ground is normal force that's not able to be used to create friction between the drive wheels and the ground.
On a different note:
Our team is still considering different drivetrain options, but we've nearly decided on a six-wheel, dropped center wheel method if we follow a differential drive design, as the ability of the robot to rock slightly will allow the robot to not be as affected by transverse friction when trying to turn. We've tested a 4-wheel differential drive and while accelerating was not as difficult as one might think, turning was not as responsive as we would like. We're waiting for two more rover wheels to test out the 6-wheel drive.
--Ryan
FRC 766, 2015-, Mentor
Unread 07-01-2009, 17:52
shannieliz's Avatar
shannieliz shannieliz is offline
AKA: Shannon
FRC #0316
Team Role: Team Spirit / Cheering
shannieliz is an unknown quantity at this point
my thinking is that it will just give you more speed.
meaning, you may go sliding more on the crater floor.
now i have no clue if this is true or not, this is just my opinion from what i've heard.
LuNaTeCs Team 316
Unread 07-01-2009, 20:40
MrForbes's Avatar
AKA: Jim
Yup. Making this decision might involve comparing the control advantge to be gained by implementing a good traction control algorithm, vs. the loss in tractive force by putting a small part of the robot's weight on the unpowered sensor wheels.
Unread 07-01-2009, 20:59
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
squirrel: The only thing I want to know is why you need normal force to create the traction control algorithm? You can do it without such a reading. All you really need is to do a little bit of math (calculus at most) and you should be able to come up with it as a simple formula. A little programming should allow you to use this formula for the traction control.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 07-01-2009, 21:06
I would normally agree with this, but in this game there is so little friction available you might be talking about the difference between nil and .95(nil). I think comparing the rotational rate of an idler wheel compared to that of the powered wheel might be useful in managing wheelspin.
Unread 07-01-2009, 21:37
MrForbes's Avatar
AKA: Jim
There are different ways to implement traction control. Having a sensor wheel is one of them. What type of system you want to use is up to you..maybe the sensor wheel type could work better or be easier to program, or eliminate the need for other sensors. If you can do it a different way, great!
Unread 07-01-2009, 21:46
rl1806's Avatar
rl1806 rl1806 is offline
AKA: Ryan Lowe
FRC #1806 (S.W.A.T.)
rl1806 will become famous soon enough
If you had a six-wheel drive with a lowered center wheel, wouldn’t the weight of the trailer only allow the center and rear wheel touch the ground? If the center and rear wheel are the only ones touching the ground, the front wheel would be doing nothing to help drive the robot.
2011-Present: SWAT FRC 1806 Mentor
2012 Rockwell Automation Innovation in Control Award [Oklahoma City]
Unread 07-01-2009, 21:48
Ferdi17 Ferdi17 is offline
AKA: Steve
FRC #1073 (The Force Team)
Ferdi17 is an unknown quantity at this point
Another thing to think about is that the trasverse coefficent of friction is greater than the inline so not only dose it matter how many wheels but if they are turned.
Unread 07-01-2009, 21:52
Deathnmasses's Avatar
Deathnmasses Deathnmasses is offline
AKA: Cody Sparks
FRC #2366 (Tesla Robotics)
Team Role: Webmaster
Deathnmasses is an unknown quantity at this point
It would not give you more traction. In fact it would do better to have less wheels so that you could get more weight onto your motorized wheels.
Unread 07-01-2009, 21:53
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I think encoders in the drive train are good enough to see slippage in the direction you are trying to go (just look for unnatural acceleration of a single wheel). Detecting slippage normal to the direction of travel is much tougher. I'd try a gyro before an optical mouse kind of thing. This is a tough surface to get an optical mouse to work well.
A couple of posts talk about the increase in traction if the floor is not smooth. This might be true but it is not because there is more surface area or a change in the coefficient. The reason is because there is now something to push against (bump/s in the material). There is an additional force term in the direction of travel.
Unread 07-01-2009, 22:38
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
According to this link, you shouldn't have problems with instrumentation slippage done in this fashion, due to the fact that you can use a higher COF wheel.
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Bad Weather - Better Now than Later archiver 2000 33 24-06-2002 00:39
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
Chief Delphi 7 Picture -- better than nothing Joe Johnson Robot Showcase 7 02-03-2002 18:55
