Go to Post I don't know if the WPILibrary has a FluxCapacitor.vi in it. - DavidGitz [more]
Unread 07-01-2009, 11:19
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Underestimating the Trailer
Originally Posted by Petey View Post
I bet it'd be hard, but I'm pretty sure it's possible. You don't need a square chassis, all you need is a way to construct your back end in such a way that the sides of the hexagon abut the back end of your bot while the trailer tongue is pulled pretty far in while also observing the other rules about attaching easily and not hitting the walls before bumpers.
e: what's the shear strength of the bolt?
Just remember that the hitch has to be on the bumper perimeter. Even if you put an indentation, the outer vertices would still define a polygon which would put your hitch not on the bumper perimeter.
Also, to EricH, you only need bumpers on 2/3 of the bumper perimetier. The entire bumper perimeter exists whether on not there are bumpers on the robot.
Unread 07-01-2009, 11:28
run the trap!!!
Team Role: Human Player
Something to think about:
Can you build a robot in such a way that the trailer's wheels are always oriented like the robot's?
Whats the advantage?
If you're dragging the trailer wheels sideways while you turn your gonna make steering much harder.
We've found that jacknifing the robot/trailer back and forth quickly is a great way to steer. Seems to work better than just plain tank steering.
-Philip J. Fry
Unread 07-01-2009, 11:55
Anna B.'s Avatar
Anna B. Anna B. is offline
has lots of NASA swag!
AKA: Anna
FRC #1735 (Green Reapers)
Anna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of light
Exactly. Instead of fighting it, why not work with it?
raising my parents blood pressure since '94
the best numbers are made up numbers
"let's call the four things A, G, Semicolon, and Pointy"
Maxima debetur puer reverentia
The greatest respect is due a child (Juvenal)
Unread 07-01-2009, 12:26
pfreivald's Avatar
AKA: Patrick Freivald
What kind of drive train did you use when you were jacknifing to steer? Tank? 4WD?
Thanks,
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2009, 12:38
Swerting's Avatar
Swerting Swerting is offline
King of the Geats
FRC #1523 (MARS)
Swerting is on a distinguished road
My team made a basic tank drive chasis from VeX kits, hooked up a trailer (also made of VeX) and drove it on a smooth table (the wheels being gears) and while it did seem to jacknife(?) quite a bit it didn't seem to matter too much since the wheels also slid fairly easily.
of course, it's just VeX on a smooth table, and it may be entirely different in competition
Six weeks is plenty of time to design and build a robot.
What do you mean that includes testing it?!?
I will forever see the first logo in my sleep.
Unread 07-01-2009, 12:51
eschanz's Avatar
eschanz eschanz is offline
B.A.
AKA: Evan Schanz
FRC #1254 (Entropy)
eschanz is infamous around these partseschanz is infamous around these parts
Send a message via Yahoo to eschanz
Exclamation Re: Underestimating the Trailer
I dont think it will be as hard as people are saying, because with less friction it will be close to impossible to get jack-knifed. This is because when you slide, the force from hitting a wall or another bot will send the trailer flying past or hit the wall (or bot) too.
Unread 07-01-2009, 12:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
FYI, unless there's something that I missed you cannot move the hitch location once the match has started. The rule regarding the trailer hitch says a rigid, fixed location which has been interpreted by most to mean that the hitch cannot be actuated.
As for detecting the trailer location, you could have ultrasonic sensors pointed out the back of the bot to where the tongue meets the trailer. If the trailer swings to one side, the range finder on that side will get shorter and the range finder on the other side will report a longer range or just noise. Of course, this assumes you already have a crab drive system and there's an actual benefit to keeping your robot wheels oriented with the trailer wheels.
2017 Scoring Model
CAD Library | GitHub
Unread 07-01-2009, 15:04
That's what I said. You only need 2/3 of it (the perimeter). Though maybe I should have added "covered" to the end.
Also note, though this is not official by any means: the trailer hitch will (most likely) take up 7" of the 1/3 uncovered. I don't think the GDC will rule that it's a bumper...
Unread 07-01-2009, 19:42
run the trap!!!
Thanks,
Patrick
4WD "long" configuration.
Tank steering.
-Philip J. Fry
Unread 07-01-2009, 20:01
pfreivald's Avatar
Tank steering.
That's nice to know. We only have a single 4x8 sheet of the FRP so far, and we were looking at 4WD tank steering, probably wide configuration... As a team that experiences a lot of ice and snow on a regular basis, we've been thinking about 'using the slipperiness' instead of somehow trying to fight it since day one.
Patrick
Team 1551
I write books, too!
Unread 07-01-2009, 20:12
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Patrick
Wouldn't today be one of those ice & snow days?
Unread 07-01-2009, 22:04
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
What if you designed the robot to be mainly driven backwards?
Have the trailer be like the "skis". When you want to turn, just jackknife the trailer and drive straight. The wheels would that way aid in turning.
Or else maybe drive forward, turn backwards.
I honestly didn't think turning would be an issue... until we tried to turn today on linoleum. If you start off spinning you're fine, if you try to turn while driving straight, you better be prepared to wait. And that's without a trailer BTW.
I think the trailer could be used advantageously, if used properly. Just some testing is needed to figure out how that would work. Hopefully we'll have a trailer by Monday. I am thinking of taking some video of it and recommend other teams to do the same, that way we can all examine it and try and figure out how to drive with this thing.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 07-01-2009, 22:27
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
If i planned on building to utilize the trailer for steering i would get practicing now.
Unread 07-01-2009, 23:02
silicon_ghoti's Avatar
silicon_ghoti silicon_ghoti is offline
AKA: I think I'm a freshman?
AKA: Luke
FRC #1425
silicon_ghoti will become famous soon enoughsilicon_ghoti will become famous soon enough
We were looking into that too, but our team came to the general consensus that FIRST was trying to articulate that the trailer hook-up was to be attached to the "outer-edge" created by the bumper polygon. For those curious about the bumper polygon it is shape created by the outermost points/corners of the robot. (Note, by definition polygons cannot have indentations, or in other words internal angles greater than 180 degrees.) But I would love for someone to prove us wrong.
What? You guys still opperate in only 2 dimensions?
This is a BEAR, it saves you.
Ghoti is pronounced "fish," ain't that sumthin'?
Unread 07-01-2009, 23:07
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
I think that if you have enough speed when you are backing up the jack-knife problem won't be a problem since the wheels on the trailer have no more traction than the robot wheels so they will slip and slide even going sideways when jack-knifed. As long as you keep some speed when going either backwards or forwards you cann still keep going into a possible orientation spot.
The Trailer measurements Nadav Gross General Forum 16 06-01-2009 22:45
Attaching the Trailer Eiske Rules/Strategy 6 04-01-2009 22:33
Trailer Available for the Championship OZ_341 General Forum 0 23-03-2008 07:25
To Trailer or Not to Trailer? Carol General Forum 14 25-06-2006 18:14
