Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 07-01-2009, 13:00
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Question Programming the axis camera......
hello, Let's just say i would like the axis camera to drive two motors connected to the digital side car pwm 1 and 2. I want the camera to follow the color. How do i do this using WindRiver? Which template should i open and how do i program this to happen? Please help me! Any help would be greatly appreciated!
"I would love to change the world but no one will give me the source code"
Unread 07-01-2009, 15:39
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
Re: Programming the axis camera......
I'm not quite sure if there is a set template that already has precompiled code like that... But I could be wrong...
If you do come across code like that (we might try something similar or would like to mess with a copy of the code...) a PM or email would be much appreciated.
I'll keep you posted with any information I get regarding this...
P.S. Just a side note... But did you even get the camera correctly configured when its connected to the cRIO?
Unread 07-01-2009, 18:14
programmr's Avatar
AKA: Face
FRC #0522
Exclamation Re: Programming the axis camera......
Yes, i did get the camera configured correctly, but im having some issues understanding how the program works.. or if i can write a more simple program for it.
Unread 07-01-2009, 21:40
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
The update for windriver that was launched after kickoff comes with a template in it. Open the "new" drop down menu and click example and you should find it there.
Unread 07-01-2009, 23:54
Software Specialist
AKA: Daniel
VRC #0646
How did you configure the camera and how do you know it's getting recognized by the cRIO? I guess that's the problem we need to work out first cause the VisionDemo and the VisionServo programs didn't work.
Unread 08-01-2009, 10:59
Leon Canidae's Avatar
Leon Canidae Leon Canidae is offline
Official Insanity
FRC #1742 (Shockwave)
Team Role: CAD
Leon Canidae is an unknown quantity at this point
Send a message via MSN to Leon Canidae
We, team 1742, are having trouble getting a feed from the camera via the cRIO. we have been able to get the camera to give us a feed while it is connected to the computer, but when we connect it to the cRIO...nothing. please help.
“Introduce a little anarchy, upset the established order, and everything becomes chaos, I’m an agent of chaos , and you know the thing about chaos? It’s fair.”
- The Joker
- "The Dark Knight"
Unread 09-01-2009, 08:16
woodk woodk is offline
FRC #2809
woodk has a spectacular aura aboutwoodk has a spectacular aura aboutwoodk has a spectacular aura about
Question Re: Programming the axis camera......
Is anyone else having problems with the new camera code released Jan 1? It will not find any colour particles at all for me. I ended up reverting VisionAPI.cpp, VisionAPI.h and TrackAPI.cpp, TrackAPI.h to the old versions and it is now working again.
In answer to the question about camera servo tracking, there is an example called "FRC Vision-Servo Demonstration Program" that supposedly does this, although again, it did not work with the new VisionAPI and TrackAPI classes. I have not tried it with them reverted. There is also an example that drives towards the green, and one other example (can't remember what it does).
Unread 10-01-2009, 06:06
Software Specialist
AKA: Daniel
VRC #0646
After much tinkering, we finally got the camera doing what we wanted it to do.
The best camera output you're going to get will be to have your camera track the colors and output the data to a console (i.e. center of gravity, etc.)
Other than that, I'm not quite sure how you're going to stream live video from the cRIO...
Unread 10-01-2009, 23:41
FRC #2809
Other than that, I'm not quite sure how you're going to stream live video from pehin...
Did you get it working using the updated (Jan 1.) TrackAPI and VisionAPI? without modification?
Our code is working great with the older versions of those classes (using 2 servos to scan, find pink and green targets and track them if they are the right way round.). However, I couldn't get the updated classes to work.
Unread 11-01-2009, 04:02
Software Specialist
AKA: Daniel
VRC #0646
I'm pretty sure we're using the updated versions... But I'm not quite sure... If anything, I heard that they're updating the camera classes on the FIRST website sometime this week or next week... You could hold off on working on the camera till then...
But yeah... I'm not sure why the old program shouldn't be incompatible with the new updated classes...
Unread 11-01-2009, 12:23
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
How did you revert the TrackAPI and VisionAPI files? I have the old files, and I think i might have managed to fix the new files, but I don't know how to get WindRiver to build using my files as opposed to the one in the update.
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
Problems with the Axis Camera popo308 FRC Control System 16 15-01-2009 19:38
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
Focusing the AXIS camera in LV Bryan Herbst Programming 3 03-01-2009 23:21
Getting feedback from Axis Camera?? *programming in C++* Straberrie Programming 3 01-01-2009 22:39
