Go to Post We also have a CNC mill and CNC lathe, but we're interested in doing this only if we can do it quickly. Milling anything takes too long for my MTV-generation attention span. :) - Madison [more]
Unread 08-01-2009, 00:09
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
pic: Traction test
Unread 08-01-2009, 00:16
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
Re: pic: Traction test
I do not know much about vex motors, but I am willing to bet that due to the less available torque for the one on the right due to the inverted gear ratio that it's acceleration was below the acceleration needed to break free.
Breaking free means reduced friction coefficient ...
Unread 08-01-2009, 00:22
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
This is a very interesting test. Thank you for sharing.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 08-01-2009, 00:30
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Just so you know, surface area in no way at all effects friction. It can effect traction though where traction is the sum of all forces you use to propel your robot. One non friction force that is included in traction is "Gripping" force. Carpet to rubber has "gripping" force which is caused by the carpet meshing like gears with the rubber. "Gripping" force is effected by surface area, more grip points more resistance. On this years surfaces, however, it is only friction.
The reason friction does not go up with surface area is that as you add contact point the weight per point (pressure) goes down, netting a even friction force. The formula for friction Ff=µ(Fn). Where Ff is Force of friction, µ is coefficient of friction and Fn is normal force (is this case weight of the robot). Te left robot most of one because of discrepancies in the wheels that made it have slightly more friction with the floor
tl;dr: Surface area doesn't effect friction, winning robot was blind luck.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 08-01-2009, 00:31
darn
and i thought we were clever.
Unread 08-01-2009, 00:35
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
I would say keep both at the same gear ratios and number of wheels.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 08-01-2009, 00:37
hipsterjr's Avatar
AKA: CJ
what happens when the only variable is the gear ratio (same # of wheels on both)?
Unread 08-01-2009, 01:02
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I agree with Copioli here, and the results are corroborated by our own experiments. We noticed that a single CIM driving a single rover wheel with all the weight on it (120lbs total or so) running on a Toughbox had much better acceleration than the same robot with two CIMS into two Toughboxes running one wheel each (with the same 120lbs).
We then measured the actual maximum tractive force provided by each setup, and discovered that there was no noticeable difference in the total force available. The reason for the difference, as we determined, is that since all the weight was on one wheel, that wheel itself could source twice as much force (and thus double the torque), but a single CIM could only input half the torque of two CIMs. Therefore, the single wheel accelerates better because it essentially has built in traction control, as it takes a lot more to put enough torque through the single wheel to slip it.
I assume you're going full power with your two robots, in which case the robot with the lower torque will be slipping the wheels less (or maybe not at all), and will have more traction than the robot that has more torque and is slipping all the wheels.
Unread 08-01-2009, 07:29
AKA: Dana P. Henry
Both robots were running at full power. All wheels were slipping right from the start of the test. We also, to add another variable, added approx a 1/2 lb weight to each robot, the tandem wheeled robot, then the single wheeled robot. In each case, the single wheeled robot won the pushing match. We did notice about a 1 degree increase in surface temp of the wheels during the pushing mathces, which quickly dissipated upon shut down.
Tonight is the next phase, dual wheels and 1:3 on both robots.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 08-01-2009, 08:36
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Originally Posted by Nuttyman54 View Post
...a single CIM could only input half the torque of two CIMs. Therefore, the single wheel accelerates better because it essentially has built in traction control, as it takes a lot more to put enough torque through the single wheel to slip it.
This sounds about right to me. Equate it to getting your car moving on a slick surface (ice). If you start in 1st gear you will most likely spin your wheels because the engine doesn't have to overcome much resistance to turn the wheels. Start in second gear and now your engine has to overcome the gearing before your wheels will spin. (This works great on a standard but not so easy to do with an automatic unless you have second gear start, my old '96 Grand Prix had it & it got me out of a few tricky spots.)
Unread 08-01-2009, 08:39
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
A few thoughts about this -
Given a perfectly level surface and a rigid chassis - how many contact points would there be on the 4 wheels vs 8 wheel? 3 points determine a plane.
So, given that the chassis and wheel assembly might very well flex a bit, and the surface may not be perfectly flat - the # of contact points and the amount of force could vary between the 4 wheel and the 8 wheel.
As stated earlier, the normal force will be divided among the number of contact points - contact points are more relavent in this case than surface area.
I believe the difference that made the 4 wheel win, is due to the 4 wheel having more contact pressure per wheel in contact, and that the gearing reduction caused that machine to slip less than the 8 wheel. I know you indicated that both machine slipped right away, but I don't think that both slipped at the same rate. My guess is that the 4 wheel slipped slightly less.
Just my 2 cents worth,
Looks like you're having fun
Mike Aubry
Unread 08-01-2009, 08:46
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Originally Posted by Rosiebotboss View Post
The robot on the right won every time. Why?
Static vs dynamic friction
Static inline 0.06
Dynamic inline 0.05
4 motors allows the wheel to reach top speed faster, then the two. The Cof, increases until it peaks at static, then approaches 0( or some value, that is less then static friction), as the wheel speed increases. Since the 4 motors reach top speed faster the can't exert their larger force, the 2 two can since they accelerate slower due to the lower torque.
Also, the force of fiction is Cof*P (pressure* Fiction) by having two wheels per side driven you decrease the pressure P (P=F/A, force/area), the force is the weight of robot, a large area will decrease your ability to move, by increasing the force of fiction. This also hurts the 4 motor design.
Thats two answers to your questions, heres the solution:
TCS, Traction Control System.
Is now an engineer thanks to FIRST.
Unread 08-01-2009, 12:17
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Are you using this year's acetal tread Rover wheels or some other variation?
It would be interesting to see the test results with this year's acetal tread Rover wheels on the FRP...
Unread 09-01-2009, 13:19
AKA: Dana P. Henry
Update:
We rebuilt the tandem wheeled robot to include a 1:3 gear ratio. So now both robots run at 300 rpm wheel speed. I didn't have my camera with me last night so I do not have any photos or video, but the single wheeled robot won the shoving match every time.
Conclusion: 4 wheel drive is the way we are going, maximizing stability and power to the ground.
Unread 09-01-2009, 13:51
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Thanks for the update. We have a running discussing going here about whether having two wheels at each corner for a total of eight wheels is better than just a single wheel at each corner (total of 4). I say it doesn't help and that having a wheel at the center would do more good because it would take some of the weigth off of the corner wheels, which would help turn.
Brian K
Team 1225 Robotics Mentor
pic: Test/Training Bot Rob2713g Extra Discussion 9 25-08-2007 15:37
pic: Custom VEX Traction Wheel Rim Chuck Glick Extra Discussion 20 03-10-2006 17:34
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: 1662 test tranny M4 Sherman Extra Discussion 3 23-05-2006 18:02
Results of traction test IBApril180 Technical Discussion 3 04-01-2003 18:56
