Go to Post We are just helping to keep Home Depot from going Bankrupt :D . - E. Wood [more]
Unread 08-01-2009, 08:39
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: pic: Traction test
A few thoughts about this -
Given a perfectly level surface and a rigid chassis - how many contact points would there be on the 4 wheels vs 8 wheel? 3 points determine a plane.
So, given that the chassis and wheel assembly might very well flex a bit, and the surface may not be perfectly flat - the # of contact points and the amount of force could vary between the 4 wheel and the 8 wheel.
As stated earlier, the normal force will be divided among the number of contact points - contact points are more relavent in this case than surface area.
I believe the difference that made the 4 wheel win, is due to the 4 wheel having more contact pressure per wheel in contact, and that the gearing reduction caused that machine to slip less than the 8 wheel. I know you indicated that both machine slipped right away, but I don't think that both slipped at the same rate. My guess is that the 4 wheel slipped slightly less.
Just my 2 cents worth,
Looks like you're having fun
Mike Aubry
pic: Test/Training Bot Rob2713g Extra Discussion 9 25-08-2007 15:37
pic: Custom VEX Traction Wheel Rim Chuck Glick Extra Discussion 20 03-10-2006 17:34
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: 1662 test tranny M4 Sherman Extra Discussion 3 23-05-2006 18:02
Results of traction test IBApril180 Technical Discussion 3 04-01-2003 18:56
