Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 08-01-2009, 10:17
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Question about Bearings?
If I mount a steal shaft to a piece of aluminum through a 1/4 inch whole, and the shaft spins pretty fast and often(say for like a roller to grab balls), is it nessisary to use a ball bearing? Thanks for the help.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 08-01-2009, 10:22
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Question about Bearings?
Not necessary, but HIGHLY recommended. The steel shaft would quickly open up the hole in the aluminum plate, then things just get worse from there.
Former Mentor Team 1771
Former mentor Team 4509
Unread 08-01-2009, 10:24
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
That was my thought, but I just didn't know if it would be a problem. Thanks for the answer.
Unread 08-01-2009, 10:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There are lots of other options that might work better than steel on aluminum (but worse than a ball bearing). How thick is the plate that you're going through? You might be able to use a bronze or plastic sleeve bearing (bushing) if it's thick enough. Otherwise, you could bolt a piece of hard plastic to the aluminum, make a large hole in the aluminum for clearance, and drill a slightly oversized (e.g. 0.01 in larger) hole in the plastic for your shaft.
Depending on the specifics of the situation (how accurate everything is, how heavily loaded the shaft is, how much you intend to use it, etc.) you might even be able to get away with running it as you described—lubrication would be a very good idea, in that case (use grease).
Unread 08-01-2009, 10:49
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
For the application depending on shaft speed and loading you could get away with an oilite bushing as well. Roller element bearings aren't always necessary.
Edit: Remember steel and aluminum are a galvanic couple and will likely corrode during shipping, so at a minimum a bushing is recommended for this.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 08-01-2009, 11:32
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Search mcmaster.com for "sleeve bearings". That should work for your application.
Collin Fultz
Unread 08-01-2009, 11:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
In automotive engines, most overhead camshafts ride directly in holes in the aluminum head, and the aluminum lasts for a long, long time. The trick? lubrication. Since you can't have oil dripping from your robot, you probably need a bushing or bearing. Which you use probably depends on load, speed, thickness of the mounting surface, and other stuff that we don't know, but you do know.
Unread 08-01-2009, 16:40
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
IGUS makes some really nice bushings for small holes like this.
You would most likely want a flanged plain bearing. Or McMaster sells plastic and bronze bushings either of which would work, and be lighter than a ball bearing.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 08-01-2009, 20:52
Dick Linn's Avatar
no team (Synergy)
While you might be able to get by with a plain hole (if properly dimensioned and finished), you'd be well advised to consider an oil-impregnated bronze bearing. They are very inexpensive in the small sizes - well under a dollar. There are a number of 1/4" inside diameter bearings of varying lengths for 50 to 75 cents each here:
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=3670
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
question about actuators pollyproof12 Technical Discussion 6 11-11-2008 16:59
A question about Eminem robot180 Chit-Chat 64 23-04-2007 00:20
Question about treads? HarryV Technical Discussion 1 15-03-2005 12:53
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Question about scoring.... Katie Reynolds Rules/Strategy 2 06-01-2002 10:37
