Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
  #46   Spotlight this post!
Unread 08-01-2009, 00:15
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
Re: Blocking your own trailer
Considering that ur trailer can not go within the frame of the robot and that arms can go outside the frame....this seems near impossible any way, but I don't think there are any rules specifically forbidding it.
  #47   Spotlight this post!
Unread 08-01-2009, 08:35
Originally Posted by Team 2811 View Post
...if you had no bumper on the back then there would be no backside barrier for the limit in terms of the rule that you cant extend past the bumper zone. If there is no bumper zone in the rear then you can extend out over the trailer.
Think about that
I think you misunderstand the meaning of BUMPER ZONE. It refers to the entire region of the arena from 1" to 7" above the floor. Wherever your robot is, a slice of it exists within the BUMPER ZONE.
The BUMPER PERIMITER is closer to what you're talking about. However, it completely surrounds a robot at the BUMPER ZONE height, and no part of the robot may extend beyond it (with exceptions for the trailer hitch and the bumpers themselves, of course).
  #48   Spotlight this post!
Unread 08-01-2009, 08:49
rally_racin'_94's Avatar
rally_racin'_94 rally_racin'_94 is offline
Rookie
AKA: Cody
FRC #2062 (C.O.R.E)
rally_racin'_94 is an unknown quantity at this point
Thumbs down Re: Blocking your own trailer
i think there is a rule that the trailer has to be conected to the outer most point of the robot
"Confidence is the key to great acts of courage"
"pain is weakness leaving the body"
  #49   Spotlight this post!
Unread 08-01-2009, 09:06
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
All it says is that:
<R18>D:
The Trailer Hitch must be located on an outer edge of the ROBOT structure such that it may easily connect with the tongue of the TRAILER (attached to the TRAILER).
There are other parts of this rule too, but there isn't any rule saying it has to be on the outer most point as far as I am aware.
  #50   Spotlight this post!
Unread 08-01-2009, 09:14
GaryVoshol's Avatar
Cogito ergo arbitro
To quote Inspector Clouseau [bad French accent] "Not anymore." [/bad French accent]
You need to keep up with the rule changes. See Team Update 1 and Robot Rules revision B. It now reads
Originally Posted by <R18>
D. The Trailer Hitch must be located on the BUMPER PERIMETER of the ROBOT structure such that it may easily connect with the tongue of the TRAILER (attached to the TRAILER).
(since 2004)
  #51   Spotlight this post!
Unread 08-01-2009, 09:23
2175 College Mentor
AKA: Alex Miller
When I read that it doesn't say it has to be on the outer most point, just as long as it is easy to attach. (outer most point being a point on the bumper perimeter as described in the update)
  #52   Spotlight this post!
Unread 08-01-2009, 09:34
GaryVoshol's Avatar
Cogito ergo arbitro
It doesn't have to be on the outermost point, but it does have to be on the BUMPER PERIMETER which is defined by the robot's outermost points:
BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS or Trailer Hitch attached) that are within the BUMPER ZONE. To determine the BUMPER PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon. The BUMPER PERIMETER may extend up to, but cannot exceed, the maximum ROBOT volume constraints defined in Rule <R11>.
(since 2004)
  #53   Spotlight this post!
Unread 08-01-2009, 09:47
2175 College Mentor
AKA: Alex Miller
That was what I was originally intending to say by quoting <R18>, sorry if I didn't get that clear the first time.
  #54   Spotlight this post!
Unread 08-01-2009, 10:50
pearldrumzach pearldrumzach is offline
FRC #0401
pearldrumzach is an unknown quantity at this point
So, does that mean that for example, if a robot was shaped like this (letters in place to form the shape; look at the lines):
III_______
II/RRRRRRR\
I/RRRRRRRR\
|__|SSS|__| (I know, bad representation, but you get the idea)
Then would the bumper perimeter be shaped like this?
III_______
II/RRRRRRR\
I/RRRRRRRR\
|_________|
Definition:
According to the definition of the bumper perimeter, if you draw a string around your robot then that defines your bumper perimeter, and that is how it would look if you took a string around and held it taut, correct?
-Zach
  #55   Spotlight this post!
Unread 08-01-2009, 10:57
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
Yes. They have stated that the intention of the rule is something along the lines of that "if your robot were to collide with a wall, the bumpers would collide before any other part of your robot would".
Ahh, here we go.
The Game Design Committee would like to elaborate on the restriction about robot
size during match play. Specifically, it’s important to read and understand the
statement in Rule <R08>, referring to the bumpers:
“…If implemented as intended, a ROBOT that is driven into a
vertical wall in any normal PLAYING CONFIGURATION will
always have the BUMPER be the first thing to contact the wall.”
This rule restricts any arms, mechanisms, hoods, etc from extending beyond the
BUMPER PERIMETER.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
  #56   Spotlight this post!
Unread 08-01-2009, 11:53
FRC #0401
But, if there were to be a cut out in the robot, then the bumper would still contact first, wouldn't it? Not that it matters for our reasons though. We had looked into making the trailer basically part of our robot, but none of us were looking at Revision B of section 8 (the complete manual file hasn't been updated with Rev. B yet). <R18> D clarified that this can't be done and the trailer must be free instead of snug in your robot.
  #57   Spotlight this post!
Unread 08-01-2009, 14:18
You are correct. Due to that update, the trailer must be attached to the bumper perimeter, which means no cutouts to brace it. (And no other braces either.)
detecting your own alliance(C++) nathanww C/C++ 17 11-01-2009 17:13
Make your own CNC whytheheckme Technical Discussion 8 25-07-2007 02:13
Make Your Own Whiteboard! buss General Forum 13 15-01-2007 17:58
Goal blocking your corral? Not a problem anymore Ricky Q. Rules/Strategy 15 04-04-2004 17:38
Making your own gearbox? ChaosMonkey Motors 15 25-05-2002 11:07
