Go to Post Woah, boulders fired. - FrisbeeFunTime [more]
Unread 08-01-2009, 11:32
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Question about Bearings?
Search mcmaster.com for "sleeve bearings". That should work for your application.
Collin Fultz
Unread 08-01-2009, 11:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
In automotive engines, most overhead camshafts ride directly in holes in the aluminum head, and the aluminum lasts for a long, long time. The trick? lubrication. Since you can't have oil dripping from your robot, you probably need a bushing or bearing. Which you use probably depends on load, speed, thickness of the mounting surface, and other stuff that we don't know, but you do know.
Unread 08-01-2009, 16:40
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
IGUS makes some really nice bushings for small holes like this.
You would most likely want a flanged plain bearing. Or McMaster sells plastic and bronze bushings either of which would work, and be lighter than a ball bearing.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 08-01-2009, 20:52
Dick Linn's Avatar
no team (Synergy)
While you might be able to get by with a plain hole (if properly dimensioned and finished), you'd be well advised to consider an oil-impregnated bronze bearing. They are very inexpensive in the small sizes - well under a dollar. There are a number of 1/4" inside diameter bearings of varying lengths for 50 to 75 cents each here:
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=3670
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
question about actuators pollyproof12 Technical Discussion 6 11-11-2008 16:59
A question about Eminem robot180 Chit-Chat 64 23-04-2007 00:20
Question about treads? HarryV Technical Discussion 1 15-03-2005 12:53
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Question about scoring.... Katie Reynolds Rules/Strategy 2 06-01-2002 10:37
