Go to Post Only two letters and one punctuation mark can describe my feelings about this... NNNOOOOOOOOOOO!!! :( - Qbranch [more]
Unread 08-01-2009, 01:28
jeetshah jeetshah is offline
AKA: Jeet Shah
FRC #0115 (Monta Vista Robotics Team(MVRT))
jeetshah is an unknown quantity at this point
Conveyor Belt
What type of belts would be good for a conveyor system
Unread 08-01-2009, 01:33
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Conveyor Belt
I'm sure there's a number of ways you could do it, but the easiest to do (probably) would be just "standard" treadmill/conveyer belt material... I don't know what it's called but it's almost always the same kinda stuff -- this black cloth/hard rubber material covered in tiny divots for traction.
This kinda stuff:
http://www.made-in-china.com/image/2...-Polishing.jpg
You could always get more complex and do a series of thinner belts, use cloth, etc, but your best bet's probably just that "standard" material imo. Seemed to work pretty well on our '06 bot.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 08-01-2009, 02:03
jmarsh24 jmarsh24 is offline
FRC #2085
jmarsh24 will become famous soon enough
Re: Conveyor Belt
Use the surgical tubing that came with the robotics kit! Its extremely light and effective...
Unread 08-01-2009, 02:12
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: Conveyor Belt
I have also heard of teams using round belting.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 08-01-2009, 06:35
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Conveyor Belt
Look up round urethane belting on mcmaster. This is what we are planning to use. It's nice because you can make any length belt you choose and it's pretty cheap.
Mentor 2415
Unread 08-01-2009, 12:09
FRC #2085
Re: Conveyor Belt
They question is.... is it a little over kill? And how much weight will it cost? The belts from conveyor belts from mc master in my concern would be too "industrial" for our needs. Any have any other ideas for something like surgical tubing, but better friction?
Unread 08-01-2009, 12:12
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Conveyor Belt
We've been looking at pictures and descriptions of a lot of 2006 robots, and there seem to be several ways to move balls without using a conventional conveyor system. Archimedes was onto something....
Unread 08-01-2009, 13:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Conveyor Belt
Actual conveyor belting is a bad idea. It's a flat belt, so it's much more difficult to get it to ride true than a round belt or V-belt or something. You'll need crowned pulleys to have reasonable odds of keeping it on, but that's dependent on how well aligned the pulleys are. If they're too far our of parallel with each other, the belt is inevitably going to walk to one side or another. They're just generally harder to get working than the round urethane belting. Which is why you see so many teams running the urethane belts.
Unread 08-01-2009, 13:11
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Conveyor Belt
My team's experience in 2006 supports what Kevin said above. We had a sponsor that donated materials for a flat belt system to elevate Poof balls to our shooter. The elevator worked well, except when it got out of alignment, lost tension, or slipped a belt. It did those things often enough to make our shooter ineffective in many matches.
I recommend using solid round conveyor belting.
Richard Wallace
since 2003
Unread 08-01-2009, 13:39
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Re: Conveyor Belt
In 06' 1741 used actual conveyor belting to pick up the poof balls and it worked wonderfully. The only problem was that it captured the balls so well one of our team members would usually have to help the field reset crew remove them. In the off season 06'-07' we modified the conveyor system to use industrial flat rubber bands and that worked just as effectively, but allowed us to cut our robot weight by nearly 10 pounds and sped up the pick up a great deal. The pickup was driven by both FP motors with the gear box. I would highly suggest a conveyor this year simply because it takes up less space than a screw type lift and it has the capability of picking up 2 balls at a time. Whereas, in other lifts you are limited to only one ball at a time. Also an interesting observation on the bands. The rollers at each end of the conveyor were made out of 3" PVC pipe with a cap on each end and rings of larger PVC glued in place to create ridges and valleys, our intent being for the bands to ride in the valleys, but they did the exact opposite. The bands tracked to the high points and stayed there quite nicely.
Unread 08-01-2009, 13:50
run the trap!!!
Team Role: Human Player
Re: Conveyor Belt
Something we have noticed about the orbit balls is that they are very springy.
If you choose to use a belt, it should be set up in such a way that it applys a good deal of force on the ball to lift it.
If your belts are too springy the balls will slip when they reach the median point between the rollers.
We've been considering using a single high tension belt, like what many teams use in their treads.
This pic , from team 45's '03 bot, is what we really want to use. Does anyone know where they got it? F.N. Sheppard, Bercoflex?
F.N. Sheppard also has these really cool "profile" timing belts that could be used as scoops to lift the balls (instead of rolling them up a channel).
-Philip J. Fry
Unread 08-01-2009, 13:56
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Conveyor Belt
this http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100388913&marketID=93& locStoreNum=1278&categoryID=525742 works well you just need to sew in to a belt and work on make it to make it track well
pm for details
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 08-01-2009, 13:57
Re: Conveyor Belt
This is exactly what flat belts do, and why they can be so problematic if you're not being extremely careful with them. Flat belts will always track to the highest point of a pulley if it's at all possible for them to do so. This means that if your pulleys aren't parallel, the belt will track to the high side of the pulley. Crowning the pulley can help with this, but not if your alignment is bad enough that a "low" side of the crown is still higher than anything else. This is also why losing tension can cause belts to ride side to side or ride up onto flanges. They're all somewhat elastic, so if there's enough stretch in them to start riding up on a flange, they'll happily do so and will soon be attempting to ride on the flange itself.
I'm not saying it's not possible to be successful with them, mind. Just that it requires a certain attention to detail.
Unread 08-01-2009, 14:04
MrForbes's Avatar
AKA: Jim
Re: Conveyor Belt
We're planning on being able to pick up two balls at once, and feed them into a screw lift. This design details are still vaporware
The screw lift does take up a lot of room, but most of that room is used to store balls, so it's not wasted.
Unread 08-01-2009, 14:22
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Conveyor Belt
We tried to make a screw lift in 2006 and it didn't work out for us. I kind of hope we can at least get a good prototype this year because I think they look really cool.
In our final 2006 design, we used a conveyor belt from flat conveyor material that was very effective. We used pvc pipe (with many "speed holes") with end caps for the rollers. We could pick up balls really well with it, and fairly easily get two balls side by side. (Unfortunately the shooting was not so good...) That said, a preliminary hand powered prototype vertical conveyor with four strands of surgical tubing worked pretty well lifting the orbit balls up 3 feet last night. One key is having a good surface opposite the conveyor to help maintain the force on the balls. The conveyor worked well enough that the render of the robot with the conveyor is still hanging on my classroom wall.
Another thing to watch out for the conveyor mangling the balls if they stay and and get pulled back down. In 2006 we would occasionally pull the balls through a 2 cm opening between the conveyor and the chassis if the hopper was full. That would probably destroy the orbit balls.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Conveyor Belt Setsanto 3D Animation and Competition 2 21-01-2008 20:51
conveyor belt materials? Salik Syed Technical Discussion 7 13-02-2006 14:51
Conveyor Belt Garth1388 Inventor 4 30-01-2006 13:33
COnveyor belt wheels sdcantrell56 Technical Discussion 4 18-01-2006 00:10
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
