Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 08-01-2009, 12:17
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
Welding
Last year my team (no. 1836) built our very first non-kit of parts chassis out of welded aluminum. This turned out to be great from a structural sense, but terrible from a time management sense as it took us two weeks to get it back from our welder (I believe it was a parent from another local team that we no longer have a connection with).
We have no professional mentors (I'm a mentor and we are all undergraduate college students) and no professional technical help at all in fact.
Sooo....our supervising teacher is trying to have us find alternatives. If there are any that will give us as strong and precise a robot frame, that would be awesome...especially if they are cost effective. But I've got a sneaking suspicion (judging by how nice our frame was last year) that nothing is going to serve our purposes as well as welding.
Unread 08-01-2009, 12:22
in between teams
AKA: Luke Van Oort
Re: Welding
80/20 Quick frame is supposed to be quite nice. It might need a little gusseting and care to make sure that the frame is strong enough for all the high speed collisions this year, but that is easier than welding without a welder.
Team 1219: 2009 - Mentor
Unread 08-01-2009, 12:26
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Welding
Welding resources aren't that hard to find. Just get your students to run around and find a machine shop or welding shop that will do it for you quick/cheap. Preseason, we explained our situation to a local welder and he gladly did it on the spot and after a few more hours, he gave it to us for free.
Welding a robot doesn't take a lot of time if you have all the parts properly cut and fitted.
Edit: FIRST is about making connections. Any car repair shop, machine shop, welding, metalworking shop is bound to have a MIG or TIG welder.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 08-01-2009, 12:32
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Welding
And the kit bot frame is very good - strong, accurate, quick to assembly and lots of mounting holes.
It is probably a little heavier than a custom designed / welded aluminum frame, but the time advantage is huge.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 08-01-2009, 12:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Welding
The kit frame is probably the best time saver there is, and it works fine for many teams in the past (although it was a different frame!)
We are still planning to use a plywood chassis this year, we have a design mostly worked out and hope to have it in Inventor very soon, and will probably post a rendering. This year's game requires a lot of teams to rethink chassis design.
edit: I have a MIG welder, but not TIG, so I don't mess with aluminum. I also have an oxyacetelyne torch, and we could weld a frame of thinwall steel tubing, as 1501 has used in past years
Unread 08-01-2009, 12:47
FRC #1836
Re: Welding
Thanks,
I've been looking into local welders. I'm starting to realize that it may not be as expensive or time consuming as my teacher is afraid it will be. It looks like we may choose to do that...I'm pushing for it anyway. Our frame is not too complicated, but building it out of the KoP chassis is a bit hard because of some of our design elements. I will definitely try working out a deal with the welder we choose...
Finally, we're an Los Angeles based team. Anybody know any welders who would like to help out? We'd definitely give them lots of credit. My team only has one sponsor, so there is plenty of room for decals on the robot and also on our website and wherever else we list these things.
Unread 08-01-2009, 13:36
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: Welding
Quick Frame..... you are funny
We have used 8020 fro two years now and it is very good for the fram but is very heavy so use a little as possible for mechanisms. Anyone who has used it knows what I am talking about when the nuts drop into the chanel, no pun intended...
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 08-01-2009, 13:52
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Welding
Another option for welding is if your local community college has a welding program approach the instructor.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 08-01-2009, 14:16
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Re: Welding
What about pop rivets? My team did that in '04, and we were able to assemble the entire bot with 2 rivets on each corner (out of angle/flat stock aluminium).
The advantage to that, is pop rivets are simple to use, are very light, and are a great pre-work for welding in case you find a good welding shop to help you out.
Just Note: Most people you meet will not be able to do Al welding, so find an automotive shop to help you. If you can find a performance automotive shop, they will almost always have aluminum welders and skills.
Unread 08-01-2009, 20:23
Dick Linn's Avatar
no team (Synergy)
Re: Welding
Two suggestions:
1. Check with local community colleges that have trade programs. You may be surprised and find both welding and machining help.
2. Join up over at http://www.hobartwelders.com/weldtalk/ and tell folks what you are doing. You may luck out and find someone in the area who will help.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Welding? tgwalker Rules/Strategy 16 17-01-2008 15:15
Aluminum Welding Flux? Gabe Technical Discussion 6 26-03-2007 13:42
Student Welding? thecheatdx General Forum 45 02-02-2006 14:08
No welding? Katie Reynolds Rules/Strategy 7 20-02-2003 17:33
WELDING BOOTY BURGLAR OCCRA 2 05-10-2001 21:22
