Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
  #31   Spotlight this post!
Unread 07-01-2009, 22:39
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Are six wheels better than four?
Yeah, I just saw that. Interesting....makes the traction control thing easier
  #32   Spotlight this post!
Unread 07-01-2009, 22:40
waterfreak#1's Avatar
waterfreak#1 waterfreak#1 is offline
nate
AKA: 6
FRC #1388 (eagle robotics 1388)
waterfreak#1 is an unknown quantity at this point
Send a message via Yahoo to waterfreak#1
Originally Posted by cziggy343 View Post
well... the title was mainly b/c i could not think of anything better... but i wanted to know if people had done experiments to prove weather or not having more wheels creates more traction. form what our team has found, it seems to come out in a wash, but i wanted to see what other people thought. any help would be appreciated
yeah we figured that six wheels is better
  #33   Spotlight this post!
Unread 07-01-2009, 22:41
DonRotolo's Avatar
Back to humble
FRC #0832
To answer the original question: Theory states that any number of wheels will be exactly the same. The reason is that each wheel takes a portion of the weight, that portion gets smaller as the number of wheels increases.
Reality is not quite so clean. More wheels give you a very, very slight advantage, possibly so small as to be difficult to measure by a FIRST team. The reasons for the advantage mostly relate to your ability to maintain more of your grip even if one wheel hits a defect in the surface that momentarily reduces friction (think dust bunny), but also include some effects related to reduced deformation of the surfaces involved.
That being said, I really do not believe that anyone will measure a difference between 4 and 6 wheels that can justify the extra 2 wheels.
Six wheels have other advantages, however, that may convince some teams to use such a drivetrain.
One thing is clear - no wheel needs 2 CIM motors driving it...
Don
  #34   Spotlight this post!
Unread 07-01-2009, 22:53
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
this question came up when we were designing some of our robot and we figured out that haveing 4 wheels is better because this year, surface area isnt going to do anything. what we found is that if you have 4 wheels, more weight is going to be distributed to each wheel while when you have 6, less weight is going to be in each wheel. if you have 4, when you meet maximum weight, each wheel is going to be getting 30 lbs each. when you have 6 wheels, each wheel gets 20 lbs each. it is a 10 lbs difference in all.
http://www.eaglerobotics.com/
  #35   Spotlight this post!
Unread 07-01-2009, 22:58
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
How does the momentum of the robot relate to this? Maximizing the weight maximises the friction, but could there some weight less than maximum that would be the optimum relationship between traction and momentum?
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
  #36   Spotlight this post!
Unread 08-01-2009, 14:00
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
If you add wheels to the outside of the robot that will help create traction against themselves too.
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
  #37   Spotlight this post!
Unread 10-01-2009, 23:13
megaman_22201's Avatar
megaman_22201 megaman_22201 is offline
FRC #1778
megaman_22201 is on a distinguished road
Smile Re: Are six wheels better than four?
please everyone keep in mind that when you are making design decisions you take into account that in the game you will ALWAYS have a trailer attached to your robot in the matches.
this will add an extra 40 pounds to your robot AND an extra set of wheels.
be sure and design your robot to include these because it will make a difference how your robot handles on the field.
hope this proves useful to the teams that read this ^_^
-Avinesh-
-Team 1778-
-----Avinesh-----
---Team__1778---
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Bad Weather - Better Now than Later archiver 2000 33 24-06-2002 00:39
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
Chief Delphi 7 Picture -- better than nothing Joe Johnson Robot Showcase 7 02-03-2002 18:55
