Thread Tools |
Rating:
Display Modes |
Re: AD22305 Gyroscope Data Sheet?
I thought it would be easy to get it working on labview, since the functions are very self-explanatory, but the indicators doesn't make sense. So I need the datasheet as well
I tried the example code and it didnt work. I set the gain at 0.007, as the sensors manual says, I also tried 0.0125 as the sample code. The "Get angle" function returns a constantly increasing value starting in zero even if I don't move the sensor.. and the "Angular rate" displays a constant value, -1.22something If I apply a regular get analog function to the gyro, I get 4,6 (volts) and it doesn't change much no matter if I turn it.. the Sensor Manual says it should be around 2,5V, so either there's something wrong with my wiring or my sensor |
| AD22305 Gyro Datasheet | pogenwurst | Sensors | 5 | 15-12-2009 17:59 |
| CIM Motor Data Sheet/Operating Temperature | Swttrt224 | Motors | 5 | 19-02-2008 16:14 |
| Accelerometer data sheet | Joe Ross | Electrical | 16 | 19-01-2005 12:26 |
| HTML version of motor data sheet from FIRST manual | Roland | Motors | 0 | 14-01-2005 22:13 |
| Here's Ed's 2nd Annual Data Sheet ...... | Ed Sparks | Championship Event | 11 | 21-04-2002 21:15 |
