Go to Post It is sad when the robots do not perform as we designed them. It is sadder still, when they perform well, but they are not victorious. However, it is most saddening when they win at a competition, and competitors are unwilling to acknowledge the teamwork and good fortune of the alliance. - Bill Moore [more]
Unread 08-01-2009, 15:52
Mac Generals Mac Generals is offline
Tony-Team 1358 Advisor
FRC #1358 (Generals)
Mac Generals is an unknown quantity at this point
Bumper Dimensions Question
If 2/3's of the robot has to be covered with bumpers, is the hitch opening inclusive in the non-bumper area measurement?
Responses will be appreciated.
Unread 08-01-2009, 15:55
Re: Bumper Dimensions Question
I'm not sure I can parse the question with enough confidence to give a simple yes or no response. The bumper only covers the part of the robot that it...covers. Is that a good enough answer?
Unread 08-01-2009, 16:20
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Talking Re: Bumper Dimensions Question
The bumper zone that is void due to the presence of the hitch counts against your bumper coverage. The maximum coverage you are able to make with the bumper is:
Your Max Possible Bumper Length = (Robot Perimeter) - (Open zone for hitch)
So the max required bumper coverage needs to be:
(Required Coverage) = [2*(Robot Perimeter)]/3
If your bumper length is greater than or equal to (Required Coverage) you are good.
I think this should just about cover it.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 08-01-2009, 16:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
This is indeed an important question to have answered...
From the manual:
BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within the BUMPER ZONE, and constructed as specified in Rule <R08>. BUMPERS are excluded from the weight and volume calculations specified in Rule <R11>.
<R08>[...]
A.
BUMPERS must be built in segments, with a minimum length of six inches, and a maximum length that does not exceed the maximum horizontal dimension of the ROBOT.
I.
BUMPERS must protect all exterior corners of the BUMPER PERIMETER (see Figure 8 - 2).
K.
BUMPERS must protect a minimum of 2/3 of the BUMPER PERIMETER. Teams are encouraged to maximize the area of the ROBOT protected by BUMPERS. But up to 1/3 of the BUMPER PERIMETER may be unprotected to provide flexibility in design options.
From Team Update 1:
BUMPER PERIMETER – the polygon defined by the outer-most set of
exterior vertices on the ROBOT (without the BUMPERS or Trailer Hitch
attached) that are within the BUMPER ZONE. To determine the BUMPER
PERIMETER, wrap a piece of string around the ROBOT at the level of the
BUMPER ZONE - the string describes this polygon. The BUMPER
PERIMETER may extend up to, but cannot exceed, the maximum ROBOT
volume constraints defined in Rule <R11>.
So, from these quotes we know the following:
1. the trailer hitch is not part of the bumper.
2. The bumper perimeter is the polygon formed by the outer-most set of vertices on the robot - basically, pretend any cutouts aren't there for these purposes.
3. Bumpers must protect 2/3 of the pumper perimeter, including all exterior corners.
So from that, i think it's safe to say that the hitch area does NOT count towards the 2/3, as the hitch is not defined as a bumper.
Some additional facts: if your bumper perimeter is the full 28x38 allowable, you're total bumper perimeter length is 132 inches. 2/3 of that is 88 inches. This means you can have 44 inches of your perimeter uncovered in this example - most likely enough to allow most of one side to be uncovered, plus the trailer hitch on another side.
Remember, each corner has to be covered, and each bumper segment has to be a minimum of 6 inches long - with a normal rectangular robot, covering the corners alone will account for 48 inches of bumper.
Bumper dimensions. IMPORTANT!! FDA1029 General Forum 6 08-02-2008 01:28
bumper question Joe G. Rules/Strategy 11 07-02-2008 02:01
bumper question stiffler Technical Discussion 2 31-01-2008 19:14
bumper question batterybox General Forum 5 17-01-2008 15:50
bumper question math4origami Rules/Strategy 4 16-01-2007 14:47
