Go to Post Success is making a difference. - SlamminSammy [more]
Unread 08-01-2009, 16:57
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: cRIO fuse??? 20 or 30?
From the data sheet, available in chapter 3 here: http://usfirst.org/community/frc/content.aspx?id=10934
3.5.2 Typical Application
** Always refer to FIRST rules for using this module in competition robots. The following sequence
describes an example application that may not fully comply with FIRST rules.
1) apply power to the DSC via J22 from a 5A (or larger) breaker on the PD
2)[...]
This typical application uses a 5A breaker... i doubt you'll need 30A for a FIRST robot.
Also, the worst that can happen if you use too small of a breaker - the breaker pops, and you put a bigger one in, after determining that it didn't pop due to a short or other hazardous electrical condition. The worst that can happen if you use to big of a breaker - your digital side car, and possibly anything attached to it, could go up in smoke.
Spike fuse JanTM1191 Electrical 3 31-01-2008 23:02
Fuse Blow Zultraranger Pneumatics 1 25-01-2008 22:28
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Need RC Fuse Yan Wang Electrical 3 03-02-2003 22:06
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
