Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 08-01-2009, 19:53
david cobbley david cobbley is offline
David
FRC #4488 (Shockwave)
david cobbley is an unknown quantity at this point
wheels need to be balanced perfectly?
Our team was thinking about it, you have between 4 to 6 wheels that are in contact with the floor. What happens if you are off in machining axles or something in your chassis and are off by a few thousands on just one wheel, the robot will rock back and forth or side to side? what do you guys think?
David Cobbley
Programming Mentor
Team 4488
Unread 08-01-2009, 20:04
Re: wheels need to be balanced perfectly?
Depends on how you're off by those few thousandths. If the axle is too thick, not much (besides the fact of tolerances).
If it's out of round or the hole is off, that's a little worse, but not a lot.
I'd like you to meet a machinist's best friend: tolerances. A few thousandths could easily be within tolerance and have almost no effect.
A few thousandths isn't much to worry about. A few tens of thousandths would be.
Unread 08-01-2009, 20:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
isn't the FRP sheeting sitting on carpet? so it will deform some with the weight of the robot on it, and the wheels will mostly all make contact (although a drop center wheel 6WD robot will always have more weight on the center wheels).
If you design the robot so the chassis can twist, like the kit frame will, then it may not be an issue because of that.
Unread 08-01-2009, 20:26
David
thats what i figured plus the surfaces of the wheels and floor arent going to be perfect, the regolith is bumpy anyways... thanks
David Cobbley
Programming Mentor
Team 4488
Need KOP 8" Wheelchair Wheels dapub Kit & Additional Hardware 4 22-02-2008 12:22
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
Need 6" wheelchair wheels! archiver 2001 5 24-06-2002 03:08
We need Omni Wheels!! archiver 2001 0 24-06-2002 01:02
In need of 8" skyway wheels archiver 2001 6 23-06-2002 22:58
