Go to Post Cooling fans? Never had the need. Then again, we're talking New Jersey in March. Radiant heaters might be a better choice, or maybe snow boots. - DonRotolo [more]
Unread 08-01-2009, 20:32
Re: cRIO fuse??? 20 or 30?
Originally Posted by eagle33199 View Post
The worst that can happen if you use to big of a breaker - your digital side car, and possibly anything attached to it, could go up in smoke.
Try to keep in mind that circuit breakers are intended to protect the wires, not the components. If the Digital Sidecar itself pulled enough current to smoke something, it was probably already broken.
Spike fuse JanTM1191 Electrical 3 31-01-2008 23:02
Fuse Blow Zultraranger Pneumatics 1 25-01-2008 22:28
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Need RC Fuse Yan Wang Electrical 3 03-02-2003 22:06
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
