We have a serious problem with our jaguars. We cannot run the motors forward. We tested the motors directly with the battery and got them to move both way. the lights on the jaguars show green. But when we probe the output of the jaguars (m+ m-) we get 0 volts. when the lights are red we get -10. On the victors we got +12. Is anyone else having this issue? All electronic components are mounted on a poly-carbonate board.
They are correctly installed, this occured while we were driving it all of a sudden stopped working.
Re: Jaguar Problem
Maybe you lost a FET or a cold solider issue.
Re: Jaguar Problem
is this happening on all jags on your drive or just one?
Re: Jaguar Problem
If the getting started guide at http://www.luminarymicro.com/jaguar doesn't help, contact Luminary Micro support at mailto:support@luminarymicro.com.
#7
Re: Jaguar Problem
Re: Jaguar Problem
Yeah i've been having the same problem, just on my benchtest i have had 2 of the 4 jaguars fail on me. it seems that if i hold it at full speed forward it ends up burning up. afterwards the forward turns green but the motor doesn't move ( reads +0 volts) and it will turn red going reverse and reads -10 volts. So you're definitely not the only one having this problem. Anyone find a solution?
| Luminary Micro / Jaguar | utlinebacker | Electrical | 8 | 13-01-2009 12:33 |
| Jaguar Motor Controller Problem | prashil27 | Electrical | 5 | 07-01-2009 21:21 |
| Jaguar deadband? | skidmarks | Motors | 1 | 06-01-2009 22:53 |
| Jaguar Failure | Jon236 | FRC Control System | 21 | 23-12-2008 18:30 |
| connecting Jaguar to Sidecar | Lakedaimon | Electrical | 2 | 15-12-2008 01:04 |
