Go to Post I heard a Lou Holtz quote as an answer to the question of "how do you motivate the unmotivated". He said " You eliminate those who are not motivated." - Scott Ritchie [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 08-01-2009, 21:20
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Success virtualizing LabView on a Mac
I have confirmed that LabView runs successfully, with full network capabilities, in VirtualBox (which is free) on a Mac.
The virtualized Windows is set to the static IP 10.xx.yy.6, and the Mac receives an IP address via DHCP. Host mode networking must be enabled for the virtual machine, and based on my testing, it only works via the wired interface. Of course, Mac OS can connect to a different network via wifi, or obtain a different IP address over the ethernet connection. I successfully imaged the cRio and deployed VIs from the virtual machine.
Finally, Labview "plays nice" with the seamless windowing mode.
David
LabView for the mac? Arkorobotics LabView and Data Acquisition 21 01-02-2010 11:52
Creating mac applications with Labview kamocat NI LabVIEW 2 21-10-2008 21:07
Camera Success?? Warren Boudreau Programming 3 16-03-2006 17:55
Success in D.C.? Bcahn836 Off-Season Events 6 23-02-2004 14:54
