Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 08-01-2009, 21:35
vmuralidharan vmuralidharan is offline
FRC #2036
vmuralidharan is an unknown quantity at this point
Is it possible too import the Auodesk Files to Solidworks?
Can our team import the parts library available at Autodesk Firstbase to Solidworks(using Autocad)? Our mentors are more familiar with solidworks. Or is there a solidworks part library?
Thanks
Unread 08-01-2009, 22:35
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Is it possible too import the Auodesk Files to Solidworks?
I generally avoid using the part library. The parts are often made individually. My experience shows that they were drawn to look good individually. Not together. You try to assemble them and you will see they don't quite line up. My guess is that you can import them, however I don't suggest you spend the time working on it.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 10-01-2009, 14:41
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
I like the parts on www.3dcontentcentral.com - look for the individual manufactures such as SMC. Also, we partnered with FIRST CAD Library to recreate a majority of Ed's parts in SolidWorks. If parts are available from manufactures in neutral file formats use STEP and import the geometry. File, Open, (select files of type STEP)
For a short cut, for parts that don't interact with any of your machined parts or moving parts, represent the part as a box with overall width, height, depth for its footprint. In the assembly, you can insert the actual weight in Tools, Mass Properties.
Marie
Solidworks KOP files nittemare SolidWorks 7 15-01-2012 18:00
Import/Export in Solidworks Mr. Steve SolidWorks 8 28-02-2010 16:01
how to import the inventor files in to 3Ds Max beschi 3D Animation and Competition 1 07-09-2007 12:26
How to create 3D dxf files in Solidworks, Inventor, or other? Travis Covington SolidWorks 6 03-05-2006 21:46
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
