Go to Post If people really want to see "better" refereeing, they should see what they can do to help FIRST make better. - petek [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2009, 11:16
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
Re: Camera pan/tilt kit
Our team kinda assembled the kit together. Problem is... most of the screws and such didn't match... so we had to make do/use whatever we felt was necessary to create the camera mount assembly.
The problem still lies in getting the cRIO to recognize the stupid camera...
Unread 07-01-2009, 13:12
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
We use the pdf from FIRST to assembly ours.
We had to drill out the servo horns to attach to the pan/tilt kit.
See pictures below for reference.
Hope this helps.
We mounted on our robot. We had some difficulty getting CRio to recognize at first but the students read the manual and got it going. We had it searching and following for the green and pink swatches in the shop yesterday. We have not decided how we will use it yet.
ID:	7098  Click image for larger version
ID:	7099  Click image for larger version
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 07-01-2009, 15:25
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Guys the camera pan/tilt is a bit hard to ensemble... The best thing is to take the camera from 2007 (teams that have) take of the camera... Drill a 4mm hole in the middle and connect the AXIS camera. i tried it and it works perfectly.
BTW... The FIRST didn't provide all the materials in the pan\tilt kit like screws for example, so i suggest using 3-4mm screws.
Unread 07-01-2009, 21:21
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Hope this helps.
The camera chassis is electrically grounded. The rules require that the ground be isolated from the robot. This is a safety issue and the inspectors will check for isolation between the robot chassis and negative battery at competition.
It looks like the best way to do this is mount the camera to a piece of plastic with the mount inside the square so that no camera metal contacts the pan tilt metal. You can attach this small piece of plastic to the pan/tile metal using nylon screws and nuts. As you build up your electrical system it's always a good idea to verify isolation from time to time. I can tell you from first hand experience that it's not a pretty sight to watch a servo cable catch fire and burn at competition!
Unread 07-01-2009, 21:45
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
http://usfirst.org/uploadedFiles/Cam...t_Assembly.pdf
but, yeah the instructions are pretty crappy. New ones possibly might arrive soon, but I'm more inclined to just use the old pan/tilt assembly as a reference.
as for looking for another one, just use Google. (I think it's called Axis 206 camera?) If yes, then it looks like a new one will be upwards of $100+
Unread 07-01-2009, 23:56
Software Specialist
AKA: Daniel
VRC #0646
To the teams that got this correctly configured and are programming in WindRiver...
Has anyone gotten the VisionServo program working with the camera plugged in?..
Unread 08-01-2009, 00:18
mbeardsworth mbeardsworth is offline
Lord of the Subversion Repository
AKA: Michael Beardsworth
FRC #2521 (South Eugene High School Robotics)
mbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of light
Do you have any detail pictures of the servo horn? I'm hesitant to drill holes in it without checking with somebody else first.
Unread 08-01-2009, 00:32
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Yikes! Why does this thing have to sit so high? Seems like there's a lot of wasted space between the camera mount and the base, especially if you are trying to mount it in some kind of protected enclosure.
I think others are right - we're going to go with the 2007 setup. It's already assembled, and seems much more robust as well.
(And if you don't have one lying around, they're still available from IFI...)
Unread 08-01-2009, 21:42
typharn91's Avatar
typharn91 typharn91 is offline
the nerdy-hippie
AKA: Mr.Gamer
FRC #0180 (S.P.A.M.)
typharn91 will become famous soon enough
Send a message via AIM to typharn91
My team found instructions just fine and I followed em and there's 2 holes on the part that attaches to the camera it fits in either one I'll try to take a pic at our next meting and post em
team shirts i have acquired 21,33,47,79,86,111,179,180,217,228,233*2,237,1114,1124,1390,1523,1557,1889,1902*2,1983 and more...ohh yeah and i can crash linux on a daily basis
Unread 08-01-2009, 22:41
AKA: Norman Morgan
I was not at school today due to a workshop. I do not have a picture of the servo horn but will take one tomorrow.
We drilled the middle hole of the three holes on each side (if that makes sense) with a drill bit just slightly smaller than the bolt. It was a simple procedure.
Win The Day!
Unread 10-01-2009, 16:43
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
We have the camera already set up in the holder (if that's what its called ) But we don't know how to keep the camera on the attachment. In the back of the main stand, where the camera should be mounted on, we don't know how to make the camera stay on.
There is no places for the screws on the back to go through the camera.
Anyone wanna help us out???
Unread 10-01-2009, 18:16
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I agree.
After looking at the 3 thumbnail pictures above, it appears there may be a missing plastic frame part that attaches to the camera first that would enable mounting of the camera tilt-pan assembly.
I'm going back into the camera packing box just to make sure I didn't miss anything. I would hate to have to drill and tap new holes into the plastic camera housing, because I'm not sure where the PCB is inside the housing.
Of course, there is always industrial-strength Velcro!
Team MARS = 1.523 AU from the SUN.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 11-01-2009, 13:38
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Yeah, i think you have to unbolt that metal mount... otherwise there's no good way to attach it.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 01-02-2009, 14:52
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Originally Posted by billbo911 View Post
They targets have always been a fixed distance off the ground. This is the first year they moving targets.
Not quite. In 2002 the Zone Zeal goals had retroreflective tape around the top of the center tubes. Targeting on a moving goal. I don't know of any teams who used a targeting system for the game.
http://www.chiefdelphi.com/media/img...aab65325_l.jpg
On a related camera note, does anyone know where to get a second pan-tilt assembly? The FIRST site does not indicate where we can order a spare.
Thanks!
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 22-01-2010, 12:01
Andrew0089 Andrew0089 is offline
FRC #3229
Andrew0089 is an unknown quantity at this point
hey, i'm on a rookie team and we are all learning so if i posted this in the wrong spot please don't get mad We got the instruction yesterday on how to build the kits but we have absolutely no clue on how to wire it up and if the code for the motors is in the pre made code that we received. and if its not could someone point me in the right direction on where to find the info for programming the kit in labview? Thank You for helping
tilt/pan away Tangello_angela Programming 4 24-01-2007 16:20
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
CMUCam pan and tilt sheyna Programming 9 14-01-2006 23:20
White Paper Discuss: Assembly of the 2006 pan/tilt camera mount Justin Stiltner Extra Discussion 2 09-01-2006 11:17
