Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 08-01-2009, 20:07
Lucario231's Avatar
Lucario231 Lucario231 is offline
FRC #0033 (Killer Bees)
Lucario231 is an unknown quantity at this point
Floor Problems
Hi
Our team has been testing with the "Regolith" floor and the tires.
When the robot is held in place the tires spin in one place on the floor and the floor then produces a powder(white) and the tire surface is damaged.
Anyone else have this issue??
thanks in advance
Unread 08-01-2009, 20:20
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Floor Problems
We noticed the same thing. Not only is the surface of wheel "roughened", the surface of the FRP is worn down. Over time, the friction coefficient increases. Early matches will be very slippery, but as competition goes on, grip will improve....in spots.
Former Mentor Team 1771
Former mentor Team 4509
Unread 08-01-2009, 20:52
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Floor Problems
I was surprised in how the coefficient of friction changed as the wheel's wear. We started Sunday on a clean school floor and measured a coefficient of 0.095 (static) and 0.085 (dynamic). We figured this would be closed enough for testing purposes and kept our practice bot light to make up for the higher coefficients. After about 10-15 minutes of driving around during the first few days of the week, we remeasured the coefficients, they're up to 0.18 (static). We now have some FRP material and get 0.11 (static) on it with our worn in wheels. What is causing a lot of the wearing in the wheels is any dust and dirt on the floor. I absolutely believe that as the floor and wheels wear in, the traction will get slightly better, but still nothing compared to previous years.
Unread 08-01-2009, 21:18
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Floor Problems
Wow, thanks for the heads-up. Does anyone know if doing this (accidentally) will be penalized as damaging the arena?
Unread 08-01-2009, 21:24
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
Re: Floor Problems
I noticed this happening as well, however, only after having driven for a while on our 4' x 8' sheet of FRP then driving on the carpet. The wheels seemed to leave a dust-like residue on the carpet.
We drove pretty carefully, since the sheet was so small, and only for a couple of minutes.
FIRST is usually very judicious about what they penalize based on field damage. I think the intent of that rule is to avoid blatant, intentional damage to the field pieces.
Unread 08-01-2009, 21:33
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Floor Problems
When they mean "damage to the field" they usually mean anything that causes actual fractures to the carpet/tile or basiclly anything that needs to be fixed beyond a small bit of duct tape to the floor.
But I wonder if the GDC knows that the floors get roughed up? I wonder if each regional gets new flooring? Maybe a Regolith Resurfacer "Zamboni" will pass over the field every so often?
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 08-01-2009, 21:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Floor Problems
FIRST isn't going to replace the floor after every regional. They wouldn't replace the carpet in the past and it was cheaper, their certainly not going to replace $1200 of flooring.
Think about the third or forth regional on a used floor or even better think about the championship after division finals on worn out floors teams come to the pristine field at Einstein.
Unread 08-01-2009, 21:50
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Floor Problems
Interesting thought, so I spawned a thread...
Unread 08-01-2009, 22:05
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
Re: Floor Problems
Not sure if you are talking about the regionals.....But FIRST replaces the carpet at every event.(At least for the past 10 years.) Last weekend at the New Hampshire KickOff it was discussed with Neil Rosenberg. (FRC Eng. Mgr) He stated the the flooring would be new for each FIRST event.
The question would be....What happens for the off-season events? Will FIRST be supplying the flooring with the field, or do the events have to find their own?
"One day you will come to a fork in the road. And you're going to have to make a decision about what direction you want to go." Boyd raised his hand and pointed. "If you go that way you can be somebody. You will have to make compromises and you will have to turn your back on your friends. But you will be a member of the club and you will get promoted and you will get good assignments." Then Boyd raised the other hand and pointed another direction. "Or you can go that way and you can do something for your country, your Air Force and for yourself. If you decide to do something, you may not get promoted and you may not get the good assignments and you certainly will not be a favorite of your superiors. But you won't have to compromise yourself. You will be true to your friends and to yourself. And your work might make a difference. To be somebody or to do something. In life there is often a roll call. That's when you will have to make a decision. To be or to do? Which way will you go?"
Unread 08-01-2009, 22:20
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Floor Problems
I can confirm that they DO replace the carpet. I can say that because we have the WI regional carpet from 06 and 07 in our shop. After the competition we brought a trailor and took the carpet with us.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 08-01-2009, 22:46
nHouse nHouse is offline
AKA: Luker
FRC #0303 (Panther Robotics)
nHouse will become famous soon enough
Re: Floor Problems
thanks for the heads up, we haven't done this kind of thing yet but i'll be sure to pass it along....
Unread 08-01-2009, 22:55
Team 1865's Avatar
Team 1865 Team 1865 is offline
FRC #1865
Team 1865 is an unknown quantity at this point
Re: Floor Problems
Thanks for the advice, this will come in handy when it comes to our game strategy....
Unread 08-01-2009, 23:08
TKM.368's Avatar
TKM.368 TKM.368 is offline
AKA: Osa
FRC #0368 (Team Kika Mana | Tiger Power!)
TKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond repute
Re: Floor Problems
So we've been driving around for a few days as well and now have a bunch of powder that's accumulated. Is it being overly cautious to be concerned with the combination of "powder" coming off of something "fiberglass" for 6 weeks???
Installation Safety:
"Wear filter mask to cover nose and mouth, especially when cutting."
MSDS:
Section 7 — Special Protection Information
Respiratory Protection (specific type) – NIOSH Approved Protective Mask That
Covers Mouth and Nose When Cutting or Machining.
Ventilation – Control Dust When Cutting or Machining
Protective Goves – Dust/Abrasive Resistant
Eye Protection – Safety Glasses or Goggles
Other Protective Clothing or Equipment – N/A
Hopefully I'm making a mountain out of a molehill...
Make a difference - VOLUNTEER!
Unread 08-01-2009, 23:10
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
Re: Floor Problems
I wonder if FIRST knows about this erosion of the playing field.
Unread 09-01-2009, 07:28
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Floor Problems
Yes, I'm sure FIRST never tested the field, never drove robots around, never built a trailer. The first time anyone every saw the field was when Woodie, Dave and Dean were demonstrating the 2-motor vs 4-motor bots at Kickoff.
C'mon folks, let's give them due credit.
(since 2004)
HDPE or ICE FLOOR R.C. Rumor Mill 60 23-01-2009 23:38
Slick floor Burnouts Wayne Doenges General Forum 0 08-01-2009 18:17
Floor Damage? BHS Bucs General Forum 8 09-02-2008 07:25
UnEven Floor??? sgsdragons Technical Discussion 18 23-01-2006 18:52
floor protection Ken Leung Off-Season Events 15 17-05-2003 07:42
