Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 08-01-2009, 21:57
Johnny2607 Johnny2607 is offline
FRC #2607
Johnny2607 is an unknown quantity at this point
Motors
Hi,
How do I go about directly connecting the wheels given in the Kit of Parts from the 2009 FIRST Robotics competition to the motor. Do i need to first attach the motor to a gear box then attach the wheel to the gear box or can i bypass the gear box. Either way how is this accomplished? In addition I would like to connect the front wheels (that will be attached to the motor) to the the back wheels with a chain.
Any help is appreciated
Thanks
Unread 08-01-2009, 22:07
logicalyrandom logicalyrandom is offline
FRC #1787 (Flying Circuits)
Team Role: Electrical
logicalyrandom will become famous soon enough
Re: Motors
yes, you should assemble the KoP gearbox first, attach the motors to that, then run a chain from the gearbox output shaft to the wheels. The FIRST website has all the guides you'll need, just look them up.
If there is no possibility of shrapnel, you did it wrong.
Unread 08-01-2009, 22:11
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Motors
In general, many of the larger motors in the Kit of Parts have too fast a shaft speed for them to be connected directly to the wheels. In fact, I would consider such a connection a safety hazard - those wheels will come apart at 3500 RPM.
So what is normally done is to connect the motor to a gear box or 'transmission', such as the AndyMark ToughBox provided in the kit of parts (look in the long chassis box). Then the output shaft of the ToughBox is connected to the wheel, either directly or through a sprocket and chain arrangement.
My advice is for you to look at images of robots in the CD Media section, to get some ideas on how teams have approached this problem. It would also be good if you could visit an experienced near-by team this week to have them explain your options.
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
