Go to Post So please, think twice before you click that little button that says "reply". - Ken Leung [more]
Unread 08-01-2009, 20:23
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Exclamation Jaguar Problem
We have a serious problem with our jaguars. We cannot run the motors forward. We tested the motors directly with the battery and got them to move both way. the lights on the jaguars show green. But when we probe the output of the jaguars (m+ m-) we get 0 volts. when the lights are red we get -10. On the victors we got +12. Is anyone else having this issue? All electronic components are mounted on a poly-carbonate board.
Unread 08-01-2009, 20:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Jaguar Problem
Sounds to me like the limit switch inputs on the Jaguar may not be properly jumpered. Check that both jumpers are installed correctly according to the Jaguar guide here.
Unread 08-01-2009, 21:28
Exclamation Re: Jaguar Problem
They are correctly installed, this occured while we were driving it all of a sudden stopped working.
Unread 08-01-2009, 21:46
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Jaguar Problem
Maybe you lost a FET or a cold solider issue.
Unread 08-01-2009, 22:41
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Jaguar Problem
is this happening on all jags on your drive or just one?
Unread 09-01-2009, 00:11
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: Jaguar Problem
If the getting started guide at http://www.luminarymicro.com/jaguar doesn't help, contact Luminary Micro support at mailto:support@luminarymicro.com.
Unread 10-01-2009, 11:48
Re: Jaguar Problem
All of them
Unread 10-01-2009, 14:28
MarkO's Avatar
MarkO MarkO is offline
AKA: Mark D. Overholser
FRC #0957 (WATSON Robotics team)
MarkO is an unknown quantity at this point
Re: Jaguar Problem
Yeah i've been having the same problem, just on my benchtest i have had 2 of the 4 jaguars fail on me. it seems that if i hold it at full speed forward it ends up burning up. afterwards the forward turns green but the motor doesn't move ( reads +0 volts) and it will turn red going reverse and reads -10 volts. So you're definitely not the only one having this problem. Anyone find a solution?
Luminary Micro / Jaguar utlinebacker Electrical 8 13-01-2009 12:33
Jaguar Motor Controller Problem prashil27 Electrical 5 07-01-2009 21:21
Jaguar deadband? skidmarks Motors 1 06-01-2009 22:53
Jaguar Failure Jon236 FRC Control System 21 23-12-2008 18:30
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
