Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 05-01-2009, 13:12
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Cover on the airlock area?
is there a cover over the airlock area? can a robot dump rocks into it from the top, or do they ahve to go through the front?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 05-01-2009, 14:26
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
Re: Cover on the airlock area?
FUELING PORTS
The corner between the Alliance Station Wall and the Guardrail System includes the AIR LOCK and the FUELING PORT. The FUELING PORT is a 48-inch wide by 19-inch tall opening in the Alliance Station Wall through which the GAME PICES can exit from the CRATER. Protecting this opening is the AIR LOCK, which is constructed of 1-1/2-inch diameter steel pipe, welded to a 1/4-inch base plate that is attached to the carpet. The AIR LOCK is oriented at a 35-degree angle between the Guardrail System and the Alliance Station Wall. The purpose of the AIR LOCK is to prevent ROBOTS, in whole or in part, from passing through the FUELING PORT and contacting any team members. It also helps prevent ROBOTS from getting trapped in the corners of the CRATER.
I believe that the airlock is open on top. There is nothing describing that it is. Of course I haven't looked at any official field drawings.
Unread 05-01-2009, 14:32
Elgin Clock's Avatar
FRC #0237 (Black Magic)
No covers:
http://www.flickr.com/photos/2242118...7611844292070/
Unread 08-01-2009, 22:48
pfreivald's Avatar
AKA: Patrick Freivald
That's tremendously strange. I was pouring over both pictures and CAD drawings trying to find out the answer to this very question. With no top to the airlock, what is the point of the lower, harder-to-use little windows?
I don't really get it, and that has made me worried that I'm missing something. I plan to ask on the Q&A, just to double-triple check this.
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-01-2009, 22:51
Ironstorm's Avatar
Ironstorm Ironstorm is offline
AKA: Sean
FRC #2729 (The STORM)
Ironstorm will become famous soon enoughIronstorm will become famous soon enough
To keep sliding robots away from the hp's hands I would guess
Unread 08-01-2009, 22:54
Yes. Also to make corner pinning harder, and to aid in field reuse. (That's right, I'm pretty sure that is a reason.)
Unread 08-01-2009, 22:56
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Patrick
The airlock structure is there to keep robots from sliding into the corner and getting stuck in an acute corner, as mentioned in Chapter 6 of the Manual. It is that simple.
-dave
Unread 08-01-2009, 22:58
pfreivald's Avatar
Thanks, Dave. That simplifies things dramatically!
Well, except for the faux ice. And the non-expansion. And the trailer.
Patrick
Team 1551
I write books, too!
Unread 08-01-2009, 22:59
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Patrick
The lower pass through allows for a simple push through which doesn't require any lifting/dumping/shooting action that may be hard for some teams to engineer and build...
Unread 08-01-2009, 23:20
Best Available Data
FRC #1778 (Chill Out!)
Patrick
I imagine its purpose is threefold:
1. As Ironstorm has already pointed out, it protects human fingers from being squished, especially in a year where robot controllability is at all time low.
2. It takes away the 90 degree corners in the field, making it less likely that robots will be jack knifed in a corner unable to get out, and making it harder for robots to corner each other.
3. It makes the challenge of designing a delivery mechanism more interesting.
The airlock area GregW11 Rules/Strategy 9 10-01-2009 21:21
Ask CNN to cover the Championship BornaE FIRST In the News... 4 10-04-2008 17:26
pic: FIRST Robots: Behind the Design (Cover) Vince Extra Discussion 25 02-04-2007 18:56
2003 FIRST Competition Manual [scan the cover, please] mtaman02 Chit-Chat 0 04-01-2003 19:50
FIRST on the cover of Design News magazine Travis Hoffman Chit-Chat 2 22-08-2002 12:49
