Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 03-01-2009, 17:29
mtnman1 mtnman1 is offline
FRC #0081
mtnman1 is an unknown quantity at this point
Installing Labveiw on Vista
Has anyone had any trouble installing labview on vista? I have installed it twice and each time when it is done i try to open labview and it says it cannot open the resource files. Any help would be appreciated i need it installed as soon as possible so i can start programming for lunacy!
Unread 03-01-2009, 23:26
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Installing Labveiw on Vista
No, I haven't had any problems installing it on Vista.
First, look at the path of the source files Labview is looking for. Then, look for the installation directory (should be something like c:\program files\National Instruments\Labview8.5). If the two don't match, try reinstalling again, but make sure to change the installation path to the path Labview is looking for.
You should also fully uninstall labview before installing it again.
Finally, if the installation path matches what Labview is looking for, you may have a larger problem, and should try and contact NI.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 04-01-2009, 10:34
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
No problems with Vista here either. When do you get the 'cannot find source' files errors? Do you see the Getting Started screen that allows you to open/create a new file?
D. Sean Kelly
Team #499
Unread 04-01-2009, 10:45
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
nope no problems for me, sorry
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 08-01-2009, 22:54
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Talking Re: Installing Labveiw on Vista
sorry if i am stating the obvious but if you were running a program while installing labview that could be it. or if you have antivirus you need to disables the feature that blocks changes and start up programs. finally DO NOT LET THE COMPUTER GO TO SLEEP WHILE INSTALLING THE PROGRAM!
Unread 08-01-2009, 23:05
EncodersRUS's Avatar
EncodersRUS EncodersRUS is offline
Zombie repelant in human shape!
AKA: Tom Hewson
FRC #2550 (OCPRO)
EncodersRUS is an unknown quantity at this point
Send a message via Yahoo to EncodersRUS
Exclamation Re: Installing Labveiw on Vista
NOOOOOOOOOOOOOOOOOOOOOOOOOO WAAAAAAAAAAAAAAAAAAAAAAAAY
The ultimate fight:
LabVIEW Programming versus people who think rationally...
LabVIEW Junkie and 2011 OCPRO Mentor
Unread 09-01-2009, 00:18
DonF DonF is offline
FRC #1277
DonF is an unknown quantity at this point
Hi
Labview was fine (as far as I can tell) on on my Vista x64. However Wind River on Vista x64 won't show me the example code. I only discovered this today by comparing it to an XP vista installation which had the example FRC code from in the demo directory. When I checked the same directory on the x64 machine the FRC code is there but does not show up in teh workbench(although 3 default examples do.)
Don
Unread 09-01-2009, 00:38
davidf davidf is offline
FRC #2850
davidf will become famous soon enoughdavidf will become famous soon enough
I have had mixed success, on a Vista 64-bit Home Edition computer LabView installed just fine, albeit very slowly, however WindRiver never made it through the install process (it just kept copying files for over 20 hours). This was on brand-new, out of the box dell computers, and I had the same result on two computers.
I could not get the firmware to update from the Vista computer, although the default dashboard program w/ camera worked.
A third computer, also brand new, but with Vista 32-bit Professional, would install neither LabView or WindRiver successfully (resource problem on LV as you described, and WR would never finish installing).
So we are downgrading all our computers to 32-bit XP...
-David
Unread 09-01-2009, 02:05
Gravitynerd's Avatar
Gravitynerd Gravitynerd is offline
FRC #0696
Gravitynerd is an unknown quantity at this point
yup working fine. mayb you didn't install/download it successfully. im prettysure that's the reason for that message comming up. and i got vista with service pack 1 running on 64bit home premium . im just gona show off here and say i got a 2.5ghz core 2 quad processor with 8 gigs of ram , 750gb 7200rpm hard drive, 768mb of video card memory, aaaaaaaaaaaaaand.......... ya that's it.
Unread 09-01-2009, 14:27
CJBrick CJBrick is offline
FRC #1296
CJBrick is an unknown quantity at this point
Run the installer as a administrator.
im running on a 64 bit vista ultamite laptop. about the worst combination for probems. but im running it fine
Unread 09-01-2009, 14:38
Mr. D's Avatar
Mr. D Mr. D is offline
AKA: Mike Dischner
FRC #1708 (AMP'd Robotics)
Mr. D is just really niceMr. D is just really niceMr. D is just really niceMr. D is just really nice
We also have Lab View on Vista, we are running a Sony Vaio with Vista Home premium. Work's with No issuse, make sure you are an admin. of the computer.
Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.- Teddy Roosevelt
Proud member of FIRST Since 2005
US Navy 1970 - 1974 USS Ranger CVA-61
Unread 09-01-2009, 14:58
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
We've had mixed results. Our students installed it on their personal laptops and no problems there. However, when we installed it on the school dell laptop running vista we had multiple problems.
The first installation was fine, however when we started runing the actual Labview program, multiple errors came up saying we were missing a bunch of files. We uninstalled and reinstalled labview again. Same errors. So then we tried finding the missing files from a laptop with no errors and copying it to the computer. After that, we could open a new blank VI but could not open any of the FRC templates.
Finally...we just reformated the whole laptop from scratch, installed Labview and no problems for now...
Unread 09-01-2009, 19:41
AKA: Tom Hewson
FRC #2550 (OCPRO)
WindRiver was the one thing that my Vista didn't like. I tried to re-download again and again and even copied a working copy- same results. Then I downloaded the full version and got the horrible news.......................
My version of Vista does not fully integrate WindRiver and will just reject the final process, even running on Vista's ghost Admin.
I still dont have the full version but enough to get by.
The ultimate fight:
Unread 10-01-2009, 00:23
T3H_K3YM45T3R's Avatar
T3H_K3YM45T3R T3H_K3YM45T3R is offline
AKA: Christopher Robinson
FRC #1737 (Project X)
T3H_K3YM45T3R is an unknown quantity at this point
I got windriver to install just fine, but I had the same problem trying to get labview to install...but one of the mentors took the labview install disk so I can't try anything for a couple of days
Unread 13-01-2009, 14:14
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
Alright I see many people are having this issue. There was a read me that said what versions of xp and vista worked with windriver or lab view. I had the windriver problem but I fixed it. Wind River only works on windows XP pro or Windows vista Business edition and above. Lab view shouldn't have any problems. We had Vista home premium and I got an error for wind river. We bought a copy of windows vista Business and there was no problems. Wind River should not have a problem on windows vista ultimate edition either. Make sure you have java installed. For Lab View un-install any previous versions of lab view before you install the new version.
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Installing a Moto Roosevelt08 Technical Discussion 3 17-04-2008 13:32
Installing windows XP over vista..... John Gutmann Chit-Chat 5 30-10-2007 01:57
installing easyC MarkH Programming 2 26-03-2006 07:33
Installing mplab Dominicano0519 Programming 2 07-03-2006 18:21
installing a tachometer greencactus3 Chit-Chat 14 07-11-2005 21:00
