Go to Post Mind you, the Q&A forum and competition officials DO take precedence over my opinion. - dtengineering [more]
Unread 08-01-2009, 23:59
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Windriver Timing the fast loops, Timer.h?
Is it okay to use the timer class in windriver for quick times. I am trying to get the time between the fast loops, but I am not sure how to achieve this. I see in the IterativeRobot.cpp that they implement a timer, maybe instead of creating my own I can get something from that one. This is how I had first though of using it with its own timer (it would start in the constructor):
void Robot::AutonomousContinuous()
	Timer->Stop();
	m_class.Process(Timer->Get());
	Timer->Reset();
	Timer->Start();
Or maybe there is a better way of doing this? I want to make sure that I am getting an accurate time if that's possible.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
timer in the robot controler MaCaBi Programming 2 06-02-2006 13:55
We geared this one really fast, so fast it caught on fire! Travis Covington Robot Showcase 18 12-02-2005 07:22
How fast is fast to get on the hill? ianbbat General Forum 76 09-03-2003 21:05
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
