Go to Post I'm not overdosed, I'm not even addicted. I just choose to never, ever, ever leave FIRST. - SL8 [more]
Unread 08-01-2009, 12:28
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Looking for roller brush
Chimney sweep? what's that? asks the fellow from Arizona
(actually a chimney sweep lives up the road from me, I see him driving his old Ford truck to work often, wearing his top hat and towing his little trailer advertising his services)
Unread 08-01-2009, 13:51
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We prototyped a sort of custom brush using thin rubber hose and holes drilled into 1" OD PVC pipe. The more rigid the rubber, the better it works. We wanted to use rubber so that it would flex in case on of the 'bristles' impales the ball. Using thin hosing allows us to interlace surgical tubing on the same roller so that the brush leads straight into the conveyor.
GitHub
Unread 08-01-2009, 15:06
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Jesse, could your team kindly post a picture of this setup? If it's ok with you guys. I'd like to see how this works.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 08-01-2009, 21:09
MrForbes's Avatar
AKA: Jim
How will Rule R05 work with brushes, which have bristles of about .015" diameter?
<R05> Exterior or exposed surfaces on the ROBOT shall not present undue hazards to the team members, event staff or GAME PIECES. Reasonable efforts must be taken to remove, mitigate, or shield any sharp edges, pinch points, entanglement hazards, projectiles, extreme visual/audio emitters, etc. from the exterior of the ROBOT. All points and corners that would be commonly expected to contact a GAME PIECE should have a minimum radius of 0.125 inches to avoid becoming a snag/puncture hazard. All edges that would be commonly expected to contact a GAME PIECE should have a minimum radius of 0.030 inches. All of these potential hazards will be carefully inspected.
Unread 08-01-2009, 21:32
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
Our team worked today on a similar mechanism, using a rotating PVC pipe with k'nex pieces sticking out of it to draw the cells in. later we changed the k'nex to pneumatic tubing, to see how a flexible bristle worked. this seemed to work just as well, with the added bonus of not getting caught in the cells.
http://i37.photobucket.com/albums/e8...0108091616.jpg
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 08-01-2009, 23:37
mbushroe mbushroe is offline
FRC #2840
mbushroe is an unknown quantity at this point
o make Found Large bristle brushes
You were all looking in the wrong areas. People who make filters for koi ponds use 5-6 inch plastic brushes several feet long to allow algae to collect on them, and they are fairly inexpensive. Check out this link:
http://www.azponds.com/filter_media.htm
Hope this helps.
Mike
Unread 08-01-2009, 23:39
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Check these monster hair brushes out.....www.adiscountbeauty.com/page292.html
Unread 09-01-2009, 00:11
I would expect that the inspectors will look very, very closely at the brushes and the rules for a few minutes, and then have a conversation with each other. After about half an hour, someone will probably notice the "should" (not "must") in the rules and pass you.
Unread 09-01-2009, 00:28
MrForbes's Avatar
AKA: Jim
Thanks Eric. I was hoping someone would volunteer to post the question on the Q&A....
Unread 09-01-2009, 00:51
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Done!
Unread 13-01-2009, 11:44
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Response from GDC on Brushes.
Rule <R05> would be applied to the entire brush construction, not the individual bristles. As such, as long as the brush was not so stiff that it would cause damage to the GAME PIECES, it is unlikely to cause a conflict with Rule <R05>. There are no other rules that would generically prohibit the use of a brush assembly to collect GAME PIECES.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 13-01-2009, 14:55
synth3tk's Avatar
AKA: David Thomas
Thanks for the word!!! It came just in time for us to review our brush design.
Unread 13-01-2009, 15:07
M. Gildner's Avatar
M. Gildner M. Gildner is offline
College Mentor
AKA: Matt
FRC #2620 (Servos)
M. Gildner is on a distinguished road
Check out your local job shop or vacuum store
Servbot?...
SERVBOT!!!
pic: The Wobot's Brush fluffy Extra Discussion 8 05-03-2009 17:13
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
Fisher Price Brush Arching?? Andy4Hawks Motors 9 26-02-2004 07:24
Drill motor brush support CharlieWilken Motors 7 29-01-2004 00:37
brush transfer archiver 2001 2 24-06-2002 00:27
