Go to Post Volunteer...it will make you see a totally different side of FIRST. - Collin Fultz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 09-01-2009, 11:33
Sincrum's Avatar
Sincrum Sincrum is offline
Why does everyone think I'm insane?
AKA: John
FRC #1875 (Purple Haze)
Sincrum is an unknown quantity at this point
Send a message via AIM to Sincrum
Can we use other joysticks? (was: Question)
Can we use joysticks other than those provided in the kit?
I have grown to have a bad reputation with a hammer
When all you're holding is a hammer, every problem looks like a nail. - artdutra04
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer. ~Stuart
Unread 09-01-2009, 11:34
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Question
Yup. Controllers with a USB connection would be easiest to implement; you can purchase adapters if necessary.
Hi!
Unread 09-01-2009, 11:35
Sincrum's Avatar
AKA: John
Re: Can we use other joysticks? (was: Question)
Thanks
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: Question
based on previous years.
Yes, and you can use other means also.
You are not necessarily just limited to using joysticks.
Unread 09-01-2009, 11:43
Sincrum's Avatar
AKA: John
Cool, We have joysticks from previous years that work well for our manipulator plan.
Unread 09-01-2009, 12:13
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Also it is easy to find the same joysticks that are in the kit at most staples but it is possible to use other joysticks or other controlers
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 09-01-2009, 12:15
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
One thing to watch out for...make sure whatever you use is available for all teams to buy (COTS item). Older joysticks may be out of production and not legal for use.
Be sure to read thru section 8
http://usfirst.org/community/frc/content.aspx?id=452
can we use a xbox controller? (was: help) akedomakona Control System 10 01-02-2006 22:40
What type of joysticks can we use? Wacko324 Control System 11 29-02-2004 10:04
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Can you use other tubing? Skabana159 Pneumatics 2 06-02-2003 22:04
can i use any other custom cylinder MAXbattlebot Pneumatics 2 19-01-2003 12:44
