Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 24-06-2002, 00:36
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
how effective do you think robots going under the bar
Posted by shaun at 2/10/2001 1:44 PM EST
Other on team #25, nbths robotics team , from nbths and bms.
I have been looking at alot of pictures of robots. And with the exception of 1 or 2, I think the task of going under the bar is going to be very hard to do, with haveing another effective job or task. I think it is just to much to compact. There are 2 robots which impressed me so far. but all in all I want to know what other people think about robots going under the bar. What jobs would be good for them.
#0047 (ChiefDelphi)
Re: how effective do you think robots going under the bar
Posted by Chris Orimoto at 2/10/2001 2:08 PM EST
Student on team #368, Kika Mana, from McKinley High School and Nasa Ames/Hawaiian Electric/Weinberg Foundation.
In Reply to: how effective do you think robots going under the bar
Posted by shaun on 2/10/2001 1:44 PM EST:
I think that going under the bar is a good skill to have. However, it would only be used to maximum efficiency if there was one or two teams of the alliance that could ONLY go over the bridge.
If you saw the pictures of ROBBE Xtreme...even bots that go under the bar can grab big balls. They are also good for goal balancing (or so I think, imho).
Just my personal thoughts...
Chris, #368
#0047 (ChiefDelphi)
Posted by Jeff Alpert at 2/10/2001 3:16 PM EST
Student on team #469, Las Guerrillas, from Lawrence Tech Univ and Rexroth/Exide/Sverdrup/Nachi/Morrell/Castang/ASCO.
After examining strategy for a while, we decided that to have ANY type of robot that could traverse the field without the use of the ramp would be a great advantage. So, we designed our robot to go under the bar. We squeeze down to a 12" maximum height, and we have pneumatic-actuated 8" wheels that drop down to allow us to climb over the 4x6. Yes, our robot is ultra-compact and packaging was a VERY big challenge. yet, we balance 2 goals on the ramp and pick up big balls. Our arm is long enough that we can be on the floor and put a ball on a goal that is balanced in the middle of the ramp. So, yes, going under the bar is and will be hard, but it seems possible. We hope everything works!
Jeff Alpert
Student
Nachi/Exide/Rexroth/LTU/Sverdrup/Morrell/ABB/ESI/Michigan Machine/Master Mfg/Castaing Family Foundation/Search Plus Intl/Consolidated Mfg/Citation Mfg/Capitol Die/Kaz Technologies/ASCO/T&C Federal Credit Union
Team 469 - Las Guerrillas
#0047 (ChiefDelphi)
Posted by Bill Beatty at 2/11/2001 10:29 AM EST
Other on team #71, Team Hammond, from Team Hammond.
As more teams discover that two robots can go over the bridge at the same time, it starts to negate any time savings that a rail hopper/limboer may have.
My two cents worth.
#0047 (ChiefDelphi)
LIMBO BOTS RULE!
Posted by erik lundoy at 2/12/2001 6:54 PM EST
Student on team #263, aftershock, from sachem and symbol, retlif, apogee, citi, ca, etc..
In Reply to: Re: how effective do you think robots going under the bar
Posted by Bill Beatty on 2/11/2001 10:29 AM EST:
ok, what is the point of using the bridge? it wastes time! our robot uses a smaller front set of wheels to jump the block on the floor, and can still fit under the bar. it is much quicker, and has an arm to drag goals around. why would anyone build something to go over the bridge? COME ON!!! its just senseless!
[IMG] code is Off
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
Lifting Robots off of the Bar archiver 2000 24 23-06-2002 22:35
'Accidently' ripping other robots apart Vipersna Rumor Mill 6 04-01-2002 23:27
