Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 09-01-2009, 14:08
kaerii's Avatar
kaerii kaerii is offline
FRC #2625
kaerii is an unknown quantity at this point
Importing from FIRST Library into Autodesk Inventor
I am currently trying to draw our robot's frame in autodesk. However, I cannot seem to import any of the provided parts from FIRST. Does anyone have any solutions to this problem?
Unread 09-01-2009, 14:26
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Importing from FIRST Library into Autodesk Inventor
I assume your running Inventor 2009 correct?, because the files aren't backwards compatible. I had no problems opening files from both the FIRST KoP or the FIRST CAD Library
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 09-01-2009, 19:53
kaerii's Avatar
FRC #2625
Oh I see. So, if you don't mind me asking, how did you open them? And yes I am using Inventor 2009.
Unread 09-01-2009, 19:57
xxsumz's Avatar
xxsumz xxsumz is offline
FRC #2625
xxsumz is an unknown quantity at this point
Well, are you sure you even have the files to begin with?
ORIGINAL PROFILE ®
► Play ▌▌ Pause ■ Stop
L 0 a D i N G . . . . .
P e R F e C T i 0 N -- T a K e S -- T i M e
Importing STEP, SAT, INV, IGES into Blender Mr-Shutter CAD 2 15-01-2008 08:23
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Importing Inventor Into 3ds max? Jeremiah Johnson 3D Animation and Competition 8 31-01-2005 21:30
help importing from inventor JeffO 3D Animation and Competition 3 20-12-2004 13:47
Importing Inventor Assemblies into 3dsMAX cyanutopia 3D Animation and Competition 1 25-02-2002 12:22
