Go to Post If only every team had a Wildstang programmer! - Jeremiah Johnson [more]
Unread 09-01-2009, 14:26
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Wago Spare
Honestly... i recommend taking your wago tool with you to lowes, home depot, or even radio shack and just finding a set of small screwdrivers that are about the same size. It'll probably be cheaper than anything else, and should work just as well...
Unread 09-01-2009, 14:30
Re: Wago Spare
I think the one with the angled blade would make it much easier to get into tight spaces.
I'm not sure what advantage the straight one has over a normal screwdriver, so I wouldn't spend money for a special wago tool, except for the angled blade one.
Unread 09-01-2009, 16:37
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Wago Spare
If you do get screwdrivers from a commercial source make sure that there is plastic between the handle and the head, you don't know what could happen.
- Arizona North
Unread 11-01-2009, 16:17
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Re: Wago Spare
A set of precision screw drivers would work great, and is pretty handy when doing electrical work.
Unread 12-01-2009, 08:51
Re: Wago Spare
The Xcelite R3323 pocket screwdriver should work very well and you probably have one in your toolbox right now. BTW, adding a litte heatshrink over the round part of the blade makes it insulated.
Lost Wago power connector 734 102 falconmaster General Forum 14 06-01-2009 13:01
help with wago falconmaster Electrical 9 26-12-2008 14:31
Wago connectors darkember Technical Discussion 6 25-12-2008 22:46
Spare a metal? (CT) TJ4nier Kit & Additional Hardware 4 24-01-2007 14:32
Spare parts? tenfour General Forum 1 28-02-2004 23:19
