Re: How To Wire The Encoder
if i connect the encoder using all 3 connections (a channel,+,-) on one pwm cable and another cable just the b channel with out the + and - will it work?
Yes, you can use the red wire in the PWM cable to supply voltage.
You certainly need at least the ground and signal wires on both channels. This allows you to tie the grounds for each wire together at the encoder. The voltage supply should come from one of the two wires. What you suggest will work, with one modification. Making the A channel PWM cable "fully wired" (i.e. +5, GND, and SIG all wired) works de facto. The B channel PWM cable should have the ground wire connected to the encoder ground, the signal wire connected to the B channel encoder wire, and the +5V wire terminated and insulated. -Jeff |
Could someone make a simple diagram for wiring the encoder? I haven't been able to figure it out from this post and I can't find any documentation.
This thread has confused me a bit...
On the digital side car's digital input/output header, the ground pins are all tied together and the power pins are all tied together. There is nothing to force you to use the power or ground pin that correspond to a given I/O pin. You need to pull (at least) one power line, (at least) one ground line and the two signal lines over to the encoder. If you want to pull plural power or ground, you may do so. I think the easiest method might be to use a 1x4 cable and using the extra two power and ground pins that are in line with the signal pins. |
| How do you wire up the Operator Interface? | iPilipino | Electrical | 6 | 22-01-2008 00:22 |
| How do you wire the wheel encoders? | Demothesis | Electrical | 2 | 17-07-2007 16:59 |
| how do you wire the team light | coolguybigt | Robot Showcase | 2 | 21-02-2007 22:18 |
| how to wire the pneumatic diagram | yara92 | Pneumatics | 0 | 17-02-2007 16:28 |
| how to add steps in the provided encoder program for the edu | Zaramel2002 | Programming | 3 | 11-02-2004 08:35 |
