Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Unread 09-01-2009, 16:15
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Jaguars working with 2.4 Ghz R/C
For those of you who are interested, the new Jaguar speed controllers will work with PWM input from a standard r/c radio receiver. I fly radio control airplanes and in the past have used my r/c airplane radio systems to quickly test drive the chassis without having to install the FIRST controller. It used to take special amplified PWM cables to adapt the Victors to the output level of the receiver. Because the Jaguar optically isolates the signal and GND the r/c receiver is able to oporate the Jaguar without this additional amplification.
Advantages of the Jaguars? EricVicenti Electrical 36 03-03-2009 20:16
Working with Gyros DavidSJohnson Programming 1 10-02-2006 00:16
Working with Potentiometers GrahamS314 Programming 11 02-02-2003 14:34
